I have a slight and I mean slight leak at the top of the timing cover on the passenger side where the timing cover meets the block right by the bolt hole. I had to take the bolt out to put the brackets on. Do I need thread sealer or what?
SO glad to hear that it's running again! Enjoy!
Well all the holes related to holding on the timing are, or should be blind unless they where at some point repaired and drilled too deep.
To be safe just put some sealer on it and then re-tighten down all the 4 bolts and two stud nuts that hold the cover on.
Little tinkering left but I think it’s actually better for me than the roller. It’s a long way to the top if you wanna rock and roll
| The Following User Says Thank You to 64speed For This Useful Post: | ||
So the leak resolved itself so I won’t look a gift horse in the mouth. Clutch is sticky coming up which I assume is air still in the line. It was a pain getting any pedal at all and then over night it got worse. So I’m thinking air moved around????
| The Following 2 Users Say Thank You to 64speed For This Useful Post: | ||
Whoo that sounds good, god thats a gorgeous car.
| The Following 2 Users Say Thank You to Gach For This Useful Post: | ||
Chris D 69 GTO Liberty Blue/dark blue T400, 9" w 3.50s, 3905lbs 461, 850 Holley, T2, KRE 310s, Comp HR 236/242D .572/.594L, RA manifolds, 11.53@114, 1.55/60 The spare: 467, 850 Holley, T2, Edelbrock Dport 310cfm w RA manifolds, Howard HFT 245/251D .561/.594L, 11.59@ 114, 1.57/ 60' |
Gach is right thats a beauty, car is excellent love the post coupes myself. what dash is that and also what sound deadener did you use on the floor?
1968 firebird cameo white on red 400 4 speed 1969 carousel red firebird 455, richmond 5 speed 1964 gto pump gas, 505 IA2 EHeads, EFI, 92 mm turbo ice cream getter in process now.... 1970 lemans hardtop, gto clone Atoll Blue 1972 Maverick powered by 2004 gto ls1 and t56 6 speed, 8.8, fox strut front end, wifes car |
Looks and sounds great!
Dakota Digital RTX. That is Amazon brand sound deadener. 50 bucks for enough to do the whole damn car
Sweet car! Sounds just as rowdy at idle as it did with the roller cam. You're going to enjoy that car.
Triple Black 1971 GTO |
It’s nasty. Actually thinking of quieter mufflers. I am a music lover and I can’t hear anything in the car
I think my thermostat is sticking. It is a 180 but it’s going to 210 then coming down and going back again and on and on
Don’t change the mufflers till you get carpet and a full interior in there as it will muffle the sound a bit.
Is the upper radiator hose hot at 180 (test with infrared gun)? Also, not sure if you’ve done so but I check every thermostat in a pot of water with a thermometer before install - so far above 50% don’t open at advertised rating - more like 10-15 degrees above it.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
| The Following User Says Thank You to grivera For This Useful Post: | ||
I’m glad to see things have finally come together.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
What I can’t hear you…LOL trust me I know the feeling.
Its a new start up, might just be working air out. Hopefully it will stabilize.
I have to get different mufflers, I can’t go thru a drive thru without cutting it off LOL. My FIL came last night and the first thing he said was it’s loud
Dynomax Super Turbo is the go-to, you might be able to get a 20" case under there, but 18" will definitely fit.
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
