#1661
For the 68 Lemans/GTO;
Upper radiator support rubbers for the big four row radiators,(PA/PC etc) Part # 9790389
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
#1662
How about some 68 GTO hideaway actuator rod seals ... ones that work. The seals that come with the repop cans last about a year.
#1663
Correct 68 lower radiator saddles for the four core radiators. Left and Right.
#1664
https://www.amazon.com/Parts-Place-P.../dp/B00H87CRHC |
#1665
Thanks for responding but they do not have the necessary offset to fit right
#1666
If not already brought up, a 67-72 style aluminum stock intake for q-jets.
Not factory part numbered or anything like that. Like an aftermarket replacement. Even better if had enough material to port RAIV size...
#1667
Already exists
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#1668
Standard port size, or the POS RAIV repop?
#1669
POS RAIV repop,
So what you are saying is you want a better quality knock off.
#1670
Good luck with that! Joe @ Parts Place did the two piece repro. Seem to have used a late '72 HO intake with it's slightly more shallow plenum floor as the sample to pattern off of. We've all seen the poor intake port alignment.
#1671
Small circular rubber for the top of the rear bumper bracket. Part # 9790141
#1672
There is a seller (i believe in Texas, maybe) that is doing them, and they don't have all the blunders. aka they fit / aka bolt-on. He had several various offerings last time i checked, its been a couple/few months |
#1673
On top of that...They reproduced the one year only cast iron cross over. Right? It fits 72 and later heads. If he reproduced the 69 to 71 crossover it have fit just about all heads.
#1674
Aluminum repo standard port would be nice too. Back get'n to old for lifting stock intake over the fender. Never under stood why no companies could at least make an equal flowing dual plane intake.
#1675
Drop-Base Air Cleaner stamped for Holley 1050
#1676
A 350 piston and a correct 350 gasket that isn't a piece of crap or cost $$$
#1677
'66 Lemans taillight gaskets
#1678
The tan plastic emblem nut for the '66 LeMans quarter letters (24 per car) They look just like J101L in your catalog, but are smaller to fit the letter's studs
#1679
15" cast honeycombs like the oversized ones. please! would be the only wheel that would make me not go cragar ss. originals are to heavy, oversized ones to big!
| The Following User Says Thank You to JUDGE3 For This Useful Post: | ||
#1680
Would be in for a set of them too ! (15") |
| The Following User Says Thank You to Baron Von Zeppelin For This Useful Post: | ||
