#161
the vacuum diaphram(?) on the carb had two lines for the 264/263 carbs - one connected to the cab body, the other (outside line) connected directly to the resiviour. the resivior does look like an AC part, but is a single line deal (can only be connected on one side) - I believe the AC vacuum resiviors were actually a different part.
#162
I was able to find a supply of nos carb choke pull off's (dual fittng) here in Toronto. He also had nos idle soleinods but they were without mounting bracket. If anyone is interested pm me.
#163
I don't know if my 1970 formula has this, I will look, mounted on firewall? by the distributor? Any pics would help. Thanks
![]() Wayne
68 Firebird Coupe 350/Auto/Air 70 RA III Formula/Auto/Air 71 T/A 455HO/Standard/Air 73 T/A 455/Auto/Air |
#164
I have two holes at the moment, but I just bought the reservoir with the help of a member.
#165
FYI,
My 563 carb vacuum break has the two vacuum hose nipples as well, and the outer port is capped. This carb came off a 70 Formula, non a/c, 4 speed, Van Nuys car, built in March. Here are some pictures of the vacuum reservoir I took off the a/c auto Formula. The last picture is of my firewall on my non a/c Norwood formula. Quote:
#166
who has a bracket for the a/c hose for sale. mine is missing
#167
1970 choke pull off gm or aftermarket?
#168
before and after
#169
I have a 71 reservoir, if anyone needs one....
I think the cali(van nuys gas cap) has a red sticker..
#171
I'll chime in with my
worth, on the quarter panel deal. I believe it may very well have been possible for a very late built '70 Firebird to have one "1970" style quarter & one "1971" style on the other side. At some point in time, it is quite conceivable the early stock was used up & the newer design was phased in to production. There would have been no reason for Pontiac to match quarters, side for side, when the difference is so insignificant. It would also stand to reason, that there were many more late cars done this same way. How late in July was this one built? |
#172
Rock,...the only way I know how to tell an original Rochester dual line pull-off from an aftermarket part, is to examine the link arm. If it's a Rochester part, it'll have a 'RP' or 'RPD' stamped into it, just like you will see on other parts like the air valve butterfies & the choke valve.
#173
I rest my case !!
#175
the EES sticker was not on the gas cap, it goes on the inside of the liscence plate. Look and you will see a triangular like indention, which matches the red sticker you are talking about...
#176
Also, one more 70 only part... the rubber/plastic plug on the cowl ,one each side .....next to the fisher body plate on the drivers side. 71 started using a rubber one that has the part number on it, 70 was sort of a generic looking plastic plug without part number embossed like 71 up used.. |
#177
rock if you're worried about perfect appearance, didn't these cars have a yellow throttle return spring?
#178
I have given up on perfect appearance, when the original parts are missing its a recovery mission. I think that I have spent enough time and money on this $10k car. Having come to the realiztion that it will never be 100% perfect or correct. Its a pontiac which in its day was a winter car for most. I will have to settle for 95% correctness but I can only accept 100% in function. I drove the car last saturday for the first time and I ran as good as it did when it was new. Just a few more minor details and it will be where it should have been when I bought it (DRIVEABLE).
#179
Also, ROCK.....pm me.. I am 99% sure I have one extra of the a/c bracket you need.and i wouldn't worry about weather or not the vacuum break is original, looks close enough to me. I have a NOS one in the box and it has a similar plastic cap on the end as yours in the picture does. I would suggest you buy a set of original style ass. v-belts from our sponsor or ames, they really look good and sort of complete an engine compartment...but yes, unrujonny is correct, yellow throttle return spring.. |
#180
thanks RAlll, could you pm me with a price for the bracket. I will paint that spring yellow thanks for the advice, as the belts go I saw the original style dated belts but it wasn't a primary concern. When this green bird arrived there was so many missig and broken parts that any new belts would get the job done.
