Old 12-23-2009, 12:07 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by NHRASuperStock455SD View Post
Sorry Tom I missed that question.
Best thing for me to ask is what exactly are you looking for and I will see if we can do it. Lynn
9.2 deck height (same as BB Chebby) how hard for your deal. I know that a few short deck Aluminum All Pontiac blocks were poured years ago.
Tom Vaught
  #162
Old 12-23-2009, 01:02 PM
tom s tom s is offline
Tom,the IIA alu blocks were 9.7,a "shorter" block but NOT a short deck.Tom
  #163
Old 12-23-2009, 01:25 PM
cgeise's Avatar
cgeise cgeise is offline
Its my understanding that a BBC is 9.8 and a tall deck is 10.2 ???
  #164
Old 12-23-2009, 01:36 PM
Tom Vaught's Avatar
Boost Engineer
Man I had a bunch of mixed concepts in my typing that time.
I was thinking -.400 from a traditional Pontiac 10.243 would be about 9.8 but many think that the Ford 9.2 deck is a better deal all around so it you were going to do a short deck then do a 9.2 vs a 9.8.
It never came out that way though. LOL
Too late to learn how to type correctly and sometimes too lazy to proofread properly. Thanks Tom S and Cgeise.
Tom Vaught
  #165
Old 12-23-2009, 03:00 PM
NHRASuperStock455SD's Avatar
NHRASuperStock455SD NHRASuperStock455SD is offline
Send a message via AIM to NHRASuperStock455SD
I know the IA-II blocks have about 0.650 on the deck. I dont see what is wrong with going down to 9.800. The Hemi guys do it all the time. They have the same deck thickness and often go from 10.750 down to 10.200 to 10.300. The really fast ones rub the sand molds and get down to 9.800. Makes for a really light piston for that short 3.75 stroke.
Lynn
  #166
Old 12-23-2009, 03:10 PM
Originally Posted by gregsgtos2 View Post
are the rav heads done yet?
Greg, the water jacketed heads are done, however we are not yet into production. We are going to spend the next few weeks in QC, flow bench, porting, etc.
Lynn
[email protected]
  #167
Old 12-23-2009, 03:17 PM
Exil Exil is offline
Lynn did you get my email? Not sure if it was the right email address in my Aol contacts.
  #168
Old 12-24-2009, 01:31 PM
Go it Exil.
Question for everyone. I have made the RA-V intake the stock height as it seems all Pontiac engines including the crate motor all had the same height so that they could go into any chassis config. Any thoughts?
Lynn
[email protected]
  #169
Old 12-24-2009, 02:46 PM
Lynn,I have a brand new shortdeck sheetmetal 2-4 intake you can borrow if you build a motor.Tom
  #170
Old 12-26-2009, 01:29 PM
Cool thanks Tom, on your short deck street engines what compression ratio seems to be working out? Tom V could probably answer another question, but we have always used the fact that a turbo doubles cubic inch relative size by enhancing induction like a big cubic inch engine draws air. So what pounds of boost is required to double relative cubic inch size?
IE....300CID = 600 CID or 400CID = 800CID @ X lbs of boost.
X = ? (my guess is 12?)
  #171
Old 12-26-2009, 01:36 PM
I try and stay with 9.5 on a N/A engine with 91 gas.I think my current engine is 10.1 and seems OK.Tom
  #172
Old 12-26-2009, 06:14 PM
taff2's Avatar
taff2 taff2 is offline
My guess, X = 14.7 psi.
  #173
Old 12-27-2009, 12:02 PM
Tom Vaught's Avatar
Boost Engineer
Lynn, tell me what the mass flow is for the 300 cid engine and the 400 cid engine and I will give you the answer, LOL
Tom Vaught
  #174
Old 12-27-2009, 04:09 PM
Tom Vaught
That is such a good answer. We sealed up my son's SC engine with our SS ring set up using the same parts otherwise, and it got tons more boost with the same pulley and same SC. I will get you some numbers for the Pontiac engines
Lynn
  #175
Old 12-27-2009, 04:14 PM
PS I am looking for a 80 TA INDY PACE Car
  #176
Old 12-27-2009, 06:33 PM
jess5780 jess5780 is offline
Send a message via AIM to jess5780
Default 80 pace car
lynn dont tell me your already looking for a car for the twins LOL
  #177
Old 12-28-2009, 01:48 PM
LOL Jeff,
They turn 10 on Jan 24. Not quite yet. I told Casey my 24 year old that I think we could build an 80 Turbo, qualify top half of Indy in stock class and put the mufflers back on and he could drive it to school in the afternoon. He is doing the same with his Super Coup T-Bird only NHRA screwed those cars. His relatively stock SC V-6 is going 11.30's at 4100lbs. That tells me the Pontiac 80 Turbo project can be way better.
My SS buddy in Dallas is part of a group that leases a spot where they almost have a proving grounds of sorts for road racing and a huge facility to operate. Jimmy Johnson has been there. I plan to build a Turbo 300 for a 80 Pace car RA-V and run it on that course. Whoop the **** out of his Corvette.
I think the 80 Indy pace car was one of the coolest cars ever built, just never uncorked.
Lynn
  #178
Old 12-28-2009, 02:44 PM
Dragncar Dragncar is offline
There is one on E Bay for a Buy It Now price of 3999.00$
  #179
Old 12-28-2009, 11:09 PM
Lynn,I have a Hogan 2-4 sheet metal V intake with 2 tops if you want to send it to Tony for dyno stuff.Tom
  #180
Old 12-28-2009, 11:47 PM
Short deck?
Lynn
