Old 03-31-2009, 06:54 AM
GREGGDOG GREGGDOG is offline
Default 73 Super Duty Choke Pull Off Part Number
Sorry, I didn't mean to hijack any thread here, I was just too ignorant to know how to start a new one in this section...
I'm just wondering if the choke pull off for a 73 trans am super duty is exclusive to the super duty or if it was the same for any other 4 barrel pontiac? Anyone know what the correct part number should be? I appreciate any help??
  #1782
Old 03-31-2009, 07:25 AM
Brewster's Avatar
Brewster Brewster is offline
Jeff, The auto dimmer car is still around and its mounted on top of the drivers fender pretty close to the windshield. Does your car have any evidence of a rear power antenna like the one pictured here ?
I might have a picture of that car some where and will look for it. I dont recall the interior color option though ?
Later,
Brew
  #1783
Old 03-31-2009, 09:13 AM
sd455hota's Avatar
sd455hota sd455hota is offline
Default fender spot
Jeff, Maybe it was for an alarm. I remember seeing cars with an added alarm and there would be a key operated switch drilled into the drivers front fender.
  #1784
Old 03-31-2009, 10:36 AM
SD73's Avatar
SD73 SD73 is offline
Gregg, it's a different part. The SD pull-off operates much faster than the non-SD versions.
  #1785
Old 03-31-2009, 12:13 PM
Brewster's Avatar
Yeah, Steve has a good thought there, and I bet he's right. Chapman probably?
  #1786
Old 03-31-2009, 03:12 PM
Thanks for the info, any idea what the correct part number is for this 73 sd choke pull-off? Does it have a part#? Is it a different number for auto vs. manual? I appreciate it mucho.
  #1787
Old 03-31-2009, 05:18 PM
schneidsd455's Avatar
schneidsd455 schneidsd455 is offline
Brew,
Chapman? What's chapman? A brand name for alarms? I've seen the auto dimmer car also, and it's just as you describe. If you find a picture, I'd love to have a copy.
Steve, I'll bet you are right.
No sign of a power antenna (or any antenna), but the quarter isn't original either. Was a power antenna available as factory option in 74? If so, wouldn't it show up on PHS? Same question for the body side moldings and door edge guards. Would either show up on PHS? I'm thinking that at least the door edge guards would, but all these options could have been easily added somewhere along the line, especially since the car was owned by the owner of the dealership that sold it.
Jeff Schneider
Alliance, NE
  #1788
Old 03-31-2009, 05:28 PM
Brewster's Avatar
Hey Jeff,
The Chapman Car Alarm was very popular back in those days and usually had a sticker in the window to warn off wood be thieves.
Body side moldings or door guards code number B84 where an option installed at the deal ship and I dont believe factory installed ? call me on this one someone ?
The Door Guards I believe came with one of the trim paks and Im trying to locate but Im not to organized here Mld-sil & hood N33 I think ?
  #1789
Old 03-31-2009, 05:45 PM
superdutybob's Avatar
superdutybob superdutybob is offline
Door edge guards, as in those that are on the rear edge of the door were a stand alone option and were not part of any package. That goes for rear hood edge and door decor. Some say it was part of custom interior but it is not. It could be ordered with or without custom interior.
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #1790
Old 03-31-2009, 07:34 PM
1973Formula 1973Formula is offline
Can we expand on the exterior chrome trim options? Would they all be listed individually on the PHS? Fender, door surround, hood, are those the only three factory options?
Thanks,
  #1791
Old 04-01-2009, 09:05 AM
Brewster's Avatar
Need more information on this one since I have always been under the impression it was part of a group pack.
There are separate code option in my book (B93 988823)for it but heard years ago that the door edge guards where included in one of the trim packages????????
what are your thoughts ????????
  #1792
Old 04-01-2009, 09:25 AM
sd455hota's Avatar
Thanks,
Chrome around the hood edge, fender edge and top of doors is one option. Other moldings, trim etc are separate options. A good example is the brown 74 SD formula that just ended on ebay. The window sticker on that car shows all those options.
  #1793
Old 04-01-2009, 09:30 AM
So is the rear of the door window opening always chrome?
  #1794
Old 04-01-2009, 10:16 AM
SD73's Avatar
From the NOS box I have, it says 7041075.
  #1795
Old 04-01-2009, 10:35 AM
sd455hota's Avatar
If I remember right there is a piece in that spot that is more stainless than chrome. It's part of what holds the weather strip in place.
  #1796
Old 04-01-2009, 01:09 PM
SD Formula's Avatar
SD Formula SD Formula is offline
Both of my 74 Formulas show the trim moldings as seperate options on my PHS. Roof moldings B80, Moldings wheel opening B96, Moldings body side B84, Moldings sill & hood B85, Guards door edge B93.
When removing an unreplaceable washer, the part will be heard hitting the floor and then vanish from the face of the earth!
  #1797
Old 04-01-2009, 01:14 PM
Brewster's Avatar
Here are a couple of those pictures regarding hardware on the fender braces.
Hope this helps, and looks like I need to get detailing before spring hits.
Brew
  #1798
Old 04-01-2009, 01:17 PM
Talking
Brew:
I don't see any pictures. You have to attach them you know? It doesn't work thru osmosis!
Bob Woodard
Brighton, MI
  #1799
Old 04-01-2009, 01:21 PM
Brewster's Avatar
Yeah, not I have them in the wrong type of file! Ahhhhhhhhhh. dam computers
  #1800
Old 04-01-2009, 01:23 PM
Those are bmp (bitmap) files.
You need to open them in a paint program.
