Old 02-18-2015, 05:13 PM
The Boss's Avatar
The Boss The Boss is offline
Good numbers, very close to my Toyota Tundra.
And go racin' in the street.
Old 02-18-2015, 05:48 PM
Norwood's Avatar
Norwood Norwood is offline
Maybe a little Norwalk Challange here.
Old 02-18-2015, 08:13 PM
Brewster's Avatar
Brewster Brewster is offline
I know the numbers aren't that impressive compared to todays cars and some trucks but this 1972 Pontiac Formula is going to be hell of allot more fun to drive
Old 02-18-2015, 08:25 PM
The Boss's Avatar
I fully agree - just messing with you a little. I laughed to myself because they are almost identical to the trucks published numbers.
Old 02-18-2015, 05:33 PM
Held for Ransom's Avatar
Alternator's sitting a little low for a car with power steering. Just saying...
Old 02-19-2015, 07:02 AM
Brewster's Avatar
Yes its amazing on some of the new motor packages available but remember were talking 1972 here
I'd still race yah though
I added a couple more pictures to enjoy, Cheers!
ID:	390653   Click image for larger version
Old 02-19-2015, 07:52 AM
165th's Avatar
165th 165th is offline
Congratulations on this milestone. Dyno days are fun days.
Good luck getting her back in the cradle!
Old 02-19-2015, 11:37 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
those are great numbers Brew, and I bet that torque curve hits the high 400's at very low rpms and is as flat as Kansas from there on up! Anymore power will only serve to make the car go sideways faster
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 02-19-2015, 06:32 PM
Brewster's Avatar
Thanks guys! It sure gets me pumped up and seeing it gets me interested in working on the car more and more. Cheers and cant wait to share it with you all this summer.
Old 02-19-2015, 06:41 PM
SD455DJ SD455DJ is offline
Hey Brew,
I talked to Dan about your dyno pulls and he was very pleased with how your stock '72 455HO numbered with the factory exhaust manifolds with only the 2-1/8" outlets, so there is definitely 10-15 more hp and torque to be found if you substituted new Ram Air Repro manifolds with the 2.45" outlets and possibly a different Q-jet carb. Even if you leave it as is 400 hp and 500 lbft of torque over a long rpm range is amazing.
Congrats & Cheers! Dennis
Old 02-19-2015, 07:39 PM
Bentwheelbob's Avatar
Isn't the difference between the two exhaust manifolds just the slight opening up of the exhaust opening? I thought I had seen that the castings were the same and that RARE just has the openings slightly enlarged. Seems like a home shop project with a die grinder and a six pack of beer.
BTW - Congrats Brew on the dyno run. Great numbers and best of all it worked with no drama or great problems. Max performance is great, but at the end of the day you want the damn thing to start and run reliably without issue.
Old 02-19-2015, 07:46 PM
Formulabruce's Avatar
Hey Brew,
I do not think you can run the stock 2-1/4 exhaust with those manifolds. I know Gardner will NOT build without a 100% verify on your manifolds..
" Long may we DRIVE !"
Old 02-19-2015, 09:34 PM
Hi Bob,
The new RARE manifolds are cast in ductile iron rather than the original grey iron which cracks with age and heat cycles, so grinding them out would severely weaken the casting further. The RARE manifolds are opened up not just at the flange, but all the way to the collector portion, therefore helping flow a little bit. From what I understand, the runners are based on the SD455 manifolds which are purported to be larger (not sure that is true but rather Pontiac lore).
Formulabruce,
Definitely the factory headpipes would not seal to the RARE 2.45" flange and is meant to accept 2.5" mandrel pipe like from Pypes.
Dennis
Old 02-20-2015, 09:30 AM
Brewster's Avatar
I am working at restoring my original manifolds right now due to cracks. Like everything else it must be dead nuts on and its a good thing my welding skills are capable. I'll be reviewing options but at this point I plan on running the stock manifolds with 2-1/2" dual exhaust (including mufflers).
The two (2) things Im waiting on correcting, one is the exhaust systems and the other is the 12 bolt rear end. For now its about being a well sorted car in the front and the rear is well the last thing one see's after I rip'em. Cheers and thanks for the ideas for future reference.
Brew
Old 02-19-2015, 10:51 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
Great work Brewster. Carbs are a pain until they're right. I'm satisfied you'll breeze past 400 a good bit before your done.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 02-19-2015, 11:17 PM
Norwood's Avatar
I know of one 400 he will be BREEZING by ;(....but he already did that
Old 02-20-2015, 12:18 AM
1971455HO's Avatar
Now that's funny!
Ol' man Smith
Son video'd this...
Old 02-20-2015, 09:43 AM
The Boss's Avatar
Brian - I've got a 3:73 10 bolt if you need it.
Old 02-20-2015, 09:47 AM
Judge273's Avatar
Judge273 Judge273 is offline
Dual exhaust on a 72 Formula? Whats the reason for that?
Mike/Illinois
Old 02-20-2015, 12:33 PM
4birds's Avatar
4birds 4birds is offline
Talking
Now THATS funny. Good one. Cracked me up!
