68 GTO glove box
Thia might be a stupid question , but does the glove box go in from the front or back? Seems like either way it is going to get bent up. Thanks in advance.
Front i took the door off.
Cuz68 |
Are you serious? The liner slips right up from the back with no problems. I don't think there would be much left of the liner if you crammed it through the small front opening!
Also does the cardboard lip lay on top of the door hinge or tuck underneath? Are there supposed to be four sheet metal clips for the door?
My RePops box enters from the rear. It has been over twenty years since my car had a glovebox, so it took a bit of trial and error to make it fit right and for the door to line up and close correctly. This is how I did it
Top and sides of box lay behind the dash opening. The bottom of the box must be bent on the corrugated lines and mounts on top of the dash but under the hinge. Two clips on the dash mount the door hinge but holes must be punched through the box for the screws to pass through. The inner screws mount the box to the hinge. Door hinge spring slides between the box and the dash Two additional clips are required for the upper side screws. They slide onto the box sides The correct tire pressure decal (not a sticker) can be found here. https://www.etsy.com/shop/GasTiresan..._id=1432903893
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
The Following User Says Thank You to OG68 For This Useful Post: | ||
Perfect, thanks.
Are 68 GTO Repops boxes better fitting that REM boxes? I know REM doesn't put clips on the bottom. |
I just used an awl to poke thru the box after it was mounted. The screws will drive through the hole
I couldn't say. I can't remember when I bought the box its been so long ago. I just installed it last week
It's best not rush these things
Ken '68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '95 Comp T/A #6 M6 - bone stock (pics) |
