66 GTO header Recommendations
I am considering installing headers to my 1966 GTO. Can anybody recommend a particular manufacture. I want a system that fits in with no problems , no cutting or adjusting frame ect.. Should i consider RamAir manifolds instead? Thank you for your time.
1 vote for Ram Air manifolds. Fit is no problem, no leaks, and you get almost the same performance as headers. Cost more, but you'll never have to replace.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
Unless you are looking to make serious horsepower, the ram air manifolds will fine. Over the years I've run most of the major brands and they've all been a pain in the a__ to some degree (some more than others). If you are dead set on headers, I've had the best luck with Dougs.
My money talks to me-it usually says goodbye! |
I think you will find this article interesting . Doug
http://www.hotrod.com/articles/hppp-...-vs-manifolds/
1979 Trans Am 307 RWHP 380RWTQ 13.8@103 1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD 1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18 1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD |
Thank you !
I agree 100% with Jerry. Most Pontiacs I've seen with headers have them hanging too low. Think speed bumps and what they'll do to low hanging tube headers. Not a good thought, and not a pretty sight to see when the two meet.
No fan of headers on a street car. If you read the article in my earlier post very little HP gain in a street driven car . My reason are
1 )with good ram air manifold and a good matching down pipe little HP lost. 2) clearance sucks with headers that alone makes headers a poor choice on street . 3) crazy amount of heat from headers making your ride uncomfortable to drive in hot weather ( at least for me) 4 ) plenty more just can't think of them. Good luck Doug
Here's one that also sums up a couple of the others....
A lot of money spent for nothing and can't substantiate the benefits of having them in the first place.... other than the noise they make, either while running or when they hit something and fall apart.
I did read the article that you posted
(http://www.hotrod.com/articles/hppp-...-vs-manifolds/) and was surprised that the Ram Air Madifolds was competative. I think I will go with them. Should I consider getting them ceramic coated? Also I would to thank everybody for their feed back. Thanks! |
Ceramic coating has it's benefits. I prefer it mainly for the help with controlling heat, helping to lower underhood temperatures. If you opt not to spend the money though, MD79TA posted an excellent alternative. Ram Air in my opinion, has the best down pipes available for the Ram Air manifolds. They seem to have the tightest unrestricted turn out of the header, keeping the pipe up closer to the body. I have both the Ram Air ceramic coated manifolds, and their header pipes.
"I know just enough to keep me here, but not enough to get me out" |
I'm glad to see this thread. I bought my '66 with tubular headers on it, and they have always been problematic. They hang too low, and have been banged up and bent to oblivion. Always had problems getting a good seal at the head flange, too. I'm getting ready to build a 400/461 for street use, and I've decided I'm not going to use tubular headers and will instead use the oversized cast headers from Ram Air Restorations. I've heard enough good things about them from people that it seems like an easy choice. While they do give up some HP compared to long-tube headers, they don't sacrifice very much torque. For a street car, tubular headers just don't seem worth it when you have a high-performance "stock" alternative without any headaches.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
I am grateful that people here give excellent advice.
