Old 10-25-2021, 01:13 AM
dataway's Avatar
dataway dataway is offline
Default 68 and 69 Winter Forum Action
Are we all ready for the winter thrash? Tons of questions as people do the off season work on their rides?
My winter list is:
Entire interior including headliner
Dash, instruments, radio and inside AC.
Under hood AC components
Glass front and rear
All weather striping except door glass
All interior and engine electrics
Got a head start on some of it.
Spring time,
Sand and shoot more clear on rear quarters and doors
Finish body work and paint/install front fenders and hood
Install front bumper and hideaways
Vinyl top
Exterior trim
Fall .... shake down cruise
Late fall ... fix problems
Winter ... fix problems
Spring Fix problems
Summer Fix problems .... etc.
Old 10-25-2021, 02:58 AM
Well, we don't have much of a winter down here so I don't think of my projects as necessarily seasonal but here's what I did to mine today. I guess you could say, "Out with the Olds, in with the....Pontiac"
Sent from my moto g stylus (2021) using Tapatalk
Old 10-25-2021, 03:03 AM
dataway's Avatar
So it had an Old's rear and you are putting a Pontiac back in?
Aren't they pretty much identical? You putting in the Pontiac just for correctness? If so .. good on you, lot of work just to make something right.
Old 10-25-2021, 11:26 AM
No, not just for correctness. Several reasons actually -
It's a 2.78 pegleg and I'm putting a 3.55 limited slip, nodular.
Also, I had to use a conversion u-joint at the rear because the Olds is slightly smaller. The biggest problem is that the u-joints use a different type of snap ring retainer between the two brands so I've been on borrowed time for all of these years with absolutely no retainer back there except for the u-bolts.
In other words, the pinion on the differential is looking for an outside snap ring (l guess) and the drive shaft is looking for an inside snap ring, the u-joint that I used doesn't have a groove for the inside snap ring except on the drive shaft yoke. The two arms that mate to the yoke don't have it.
Old 10-25-2021, 11:54 AM
This is the u-joint that was in the car. Notice that two of the legs have the groove for the snap ring, plus they are slightly smaller. Those are the ones that are sized for the pinion on the Olds rear. The larger ones with the snap ring grooves press-fit into the Pontiac driveshaft.
Maybe the drive shaft on an Olds has the something for the outside snap rings? Or maybe the actual Oldsmobile u-joint has the snap ring grooves. I don't know.
Old 10-25-2021, 01:24 PM
OG68 OG68 is offline
Greg, does that have the Vista Cruiser rear drums and backing plates? The drums would be 2 1/2" wide and may be worth more than the axle itself to a Buick or Olds wagon guy. Saw a set at the San Diego swap meet a few years ago. IIRC the seller was asking $750 for the pair. Claimed the rear drums were no longer available.
2007 Cadillac SRX
Old 10-25-2021, 03:01 PM
Verdoro 68's Avatar
I'm gathering pieces to do an engine refresh and deep clean of the engine bay. Over the summer the A/C compressor slung gunk all over the place. Planning on pulling the engine once I get a timeline on when the machine shop can do my heads.
My to do list:
- Pull the engine
- Reseal leaky pan and/or rear main (not sure which one it is)
- Get the RAII heads cleaned up and ready to install
- Port match the repro RAIV intake
- Swap the cam to something the pairs well with the heads.
- Clean and detail the engine bay
Pretty loose timeline on all this as we recently moved and house projects are competing for time and money.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
Old 10-25-2021, 03:50 PM
dataway's Avatar
Yep, right now I'm at a bit of standstill getting the house ready for the extended family to come over and inspect it for errors on Thanksgivings
The drums in the photo look every bit of 2+" to me
Old 10-25-2021, 05:01 PM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Ethanol dyno tune
Remove all old gauges (using Holley Dash now)
Install new pillars
Install Halo headlights with blue ring
Complete interior light issues, dash and trunk
Fix horn relay
Possibly get the front endura bumper repaired and repainted. Shop seems a bit reluctant to attempt vs buying a new one. Worried years from now the cracks in new locations will piss me off and make their fixes seem like they didn't do their job.
Install new chrome quarter trim
There's probably more but for now, that'll make me feel really good about 2021 and the cars future after the amount of $$ I just spent on it. Ouch
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 10-25-2021, 05:33 PM
Wow, Greg, you’re about to have a lot more fun with your car.
The Following User Says Thank You to will slow gto For This Useful Post:
Old 10-25-2021, 05:36 PM
This sounds like an awesome project/build. Did you ever dyno your D-port YS? Would be cool to see before/after numbers. Good luck with everything!
My to do list:
- Pull the engine
Old 10-26-2021, 11:50 AM
Verdoro 68's Avatar
I never have, but it's set up almost identically to Roger's engine in this thread aside from the fuel injection. 425hp/480tq - surprisingly strong!
Ken
Old 10-27-2021, 02:40 AM
With my luck it probably HAD them but l put brand new drums on several years back so no chance. As for this 'O' rear, it's weird in that it is clearly stamped 'T1' but that code doesn't exist as far as I've been able to find.
Old 10-29-2021, 12:16 PM
Verdoro 68's Avatar
Trying to motivate myself to get rolling on this project! After lugging these parts out last night, I realized the first step is getting the garage situated after the move. Things are still in relative disarray out there. Plus, whomever built the house put ONE electrical outlet in for the whole garage.
Ken
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 10-29-2021, 02:02 PM
dataway's Avatar
Not sure if you have any electrical experience ... but wiring the shop is kind of a fun project. Bite the bullet and do it up right and it will make your life so much easier in the future.
I lived with a jury rigged system that I installed to get up and going quick when we built the house, 15 years later I did it right, all armored BX cable tap-conned to the walls, various 220v outlets in strategic locations etc. No more extension cords run everywhere.
Do it while the shop is empty ... kind of a pain later after work benches are such are installed.
Old 10-29-2021, 03:36 PM
1969 Ram Air 1969 Ram Air is offline
My 69 4-speed GTO is getting a new coat of Verdoro Green. I am adding hideaways, Rally II's, disc brakes and deleting the vinyl top.
Name:	verdoro - body shop.jpg
ID:	576488   Click image for larger version
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
The Following User Says Thank You to 1969 Ram Air For This Useful Post:
Old 10-29-2021, 04:16 PM
dataway's Avatar
Looks pretty freakin nice the way it is, hideaways would be a nice touch. That vinyl top makes them look classy, specially black on green.
Old 10-29-2021, 04:43 PM
It was a nice driver, 68k original miles and mostly original paint. But it had rust in the lower fenders, behind the passenger side rear wheel and around the back glass.
Old 10-29-2021, 05:10 PM
Yeah, that's a nice car. It's very refreshing to see them every once in a while with white walls and hubcaps.
Old 10-29-2021, 07:05 PM
dataway's Avatar
Do it up like that again, put on a PMD polo shirt, get the right hair cut and go to a Pontiac rally as a PMD exec
