Old 08-22-2021, 07:41 PM
scld1354's Avatar
scld1354 scld1354 is offline
Default High temps inside car
The car is a 67 Tempest 4 door hardop. Every time I drive it, it gets really hot inside the car. The vent/heat doesnt work (yet) so I doubt the heater is stuck on.
According to my Sunpro gauge pack, the engine runs anywhere between 195 and 210 depending on outside temp and driving conditions. It doesnt seem to have any impact on inside temps.
Does anyone have any ideas why its so hot inside the car? Was the factory insulation decent? Could it have broken down over time?
Sent from my SM-A505U using Tapatalk
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 08-22-2021, 08:32 PM
chrisp chrisp is offline
Add a shut off valve to the heater core.
The Following User Says Thank You to chrisp For This Useful Post:
Old 08-22-2021, 09:56 PM
scld1354's Avatar
I was just under the dash replacing the neutral safety switch (column shift auto trans). The steering column where it passes through the firewall was hot. I wonder if the driver side exhaust manifold is heating up the steering column tube?
Old 08-22-2021, 10:24 PM
ID67goat's Avatar
ID67goat ID67goat is online now
Do you have the firewall insulation installed? Are there any open holes in the firewall that would allow heat to enter the passenger compartment? Any kind of insulation installed under the carpet?
Old 08-22-2021, 10:48 PM
scld1354's Avatar
The factory firewall insulator is still there and the under-carpet insulation is still there, too. I haven't seen any holes on the firewall yet.
Old 08-24-2021, 10:32 AM
scld1354's Avatar
Right after i got home from work last night I took a temp reading of the steering column tube where it comes through the firewall. It was 140⁰!!!! I think the heat is coming from the drive side exhaust manifold.
What should exhaust manifold temps be for a stock engine?
Old 08-24-2021, 01:13 PM
geeteeohguy's Avatar
Exhaust manifolds will get up over 400-500 degrees. Normal. I've been driving first-gen A bodies for over 40 years and have never had your issue. Is your manifold TOUCHING your steering column? Where else is heat coming in? Did you check the heater box? My bet is your heater is stuck on. These cars don't get very hot inside unless it's the middle of summer.
Jeff
Old 08-24-2021, 04:48 PM
Big Bear's Avatar
Big Bear Big Bear is offline
Try the fix that chrisp mentioned. Cut the hot water to the heater core is a start.The rubber on your dampers in the heater housing might be toast. If your in Socal that heat could cook any soft parts. My rag top came from there. Anything that was soft is now petrified.
The Following User Says Thank You to Big Bear For This Useful Post:
Old 08-24-2021, 07:43 PM
scld1354's Avatar
The steering shaft is not touching the exhaust. There seems to be plenty of room.
I took a quick look at the seals/grommets on the firewall. The speedo cable grommet is missing. Everything else seems like it's there. (But every piece of rubber under the hood is cracked so maybe they are still letting in heat??) I have a replacement speedo cable grommet for a Grand Prix that may work. I'm going to try to get that in tonight.
I will also bypass the heater core tonight and see if that makes any difference.
Old 08-25-2021, 11:06 PM
scld1354's Avatar
Tried bypassing the heater core and installing the speedo cable grommet. It didnt work. The steering shaft tube/steering column is still 140⁰ where it passes through the firewall.
Old 08-26-2021, 12:14 AM
ID67goat's Avatar
Bypassing the heater core will not help with the steering column heat, but maybe with the overall heat in the passenger compartment....did you test to see how hot the interior got with the heater core bypassed?
140 degrees probably is not that bad, I am willing to bet that my headers are producing a much higher heat load into the firewall than your manifolds, but I have never checked it as you are.
Can you peel back the carpet and take some more measurements? Maybe the heat is coming through the firewall/floor from entire exhaust system? In that case maybe all you need is some more insulation material installed under the carpet.
Old 08-26-2021, 02:39 AM
Default With the heater core bypassed, run the blower motor on HEAT to move air.
Do the kick panel vents work? If the car is moving, the kick panel vents are open, the windows are down and the vent windows are open all the way, it's usually windy inside but bearable.
These years can get pretty hot inside if the air is stagnant.
Sometimes just moving air around will help. If you blow some extra air past your feet with the heater - with no hot water in the core - it may help.
But, in all honestly, I've never used a temp gun on a steering column, so 140* might be normal.....
Old 08-26-2021, 12:44 PM
scld1354's Avatar
Its an AC car, so no fresh air vents in the kick panels. The vent doesnt work yet, either (one of the things on my list to fix). The only relief is with all the windows down and the vent windows turned so air is directed toward my lap.
I've driven old cars forever and have never felt this much heat coming from the firewall and floors.
Old 08-27-2021, 07:55 AM
Andre's Avatar
Andre Andre is offline
The a/c system requires vacuum to close and open certain doors internal to the air box. Without sorting that out, one of the previous answers was to stop the flow of hot coolant to the heater core. That would be your easiest effort, and will probably part of the problem.
Old 08-29-2021, 01:00 PM
scld1354's Avatar
I blocked it off. There was not any noticeable difference. I am planning on replacing carpet soon, and will replace insulation while I have everything apart.
In the meantime, it's still hot!
Old 08-29-2021, 01:09 PM
ZeGermanHam's Avatar
I'd highly consider adding a thermal barrier while you're doing that work. The factory style insulation helps, but there are modern products these days that are more effective.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
