Fuel starvation solved
Hey guys just checking back in on my progress with my 69 Firebird 400. Was having issues with my car falling on it face in second gear from fuel starvation. Updated the old nasty fuel lines with new stainless 3/8 fuel line to a Robbmc 550 pump and a Robbmc 1/2 inch sending unit(no sock) and an adapter to go from 1/2 inch hose to 3/8. Running a 40 micron Robbmc fuel filter before carb and was running a 100 micron Robbmc fuel filter before the pump. was still falling on its face. After a suggestion by a member here I took off the pre filter to the pump and HELLO! Im pulling HARD through all three gears and no clattering. Wanna thank Darby for the advice.
1969 Firebird "400". 408 Pontiac, #62 heads, 274 XE cam, Eddy RPM intake, Quick Fuel Slayer 750, Carter Super Street fuel pump, Mallory Unilite, Turbo 400 with shift kit, Continental "Jim Hand Special" 3200 stall, 12 bolt 4.10 posi. 1 5/8 inch headers, 2.5 exhaust with Dynomax Ultraflos. |
The 100 micron was a restriction? Hm, one wouldn't think so, it should have worked. Did you happen to call RobbMC and mention that fact?
Don't you need some sort of "strainer" before the pump?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
I have the RobbMc filter before the pump and no fuel issues at all.
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
I have the small (150gph) RobbMc 100 micron before my pump also. I got rid of the sock (what was left....) and installed the RobbMc just outside the tank.
I here ya guys but this filter was causing me to stall just driving normal. My try a diff brand but since I have a new tank and pickup so not real concerned about big chunks messing up my mechanical pump
Very strange. Any chance you got the 40 micron and 100 micron filters swapped somehow?
If you bought both of them from us at the same time, I usually put a RobbMc decal on the 40 micron filter so you can easily tell them apart. Also, did you check the filter after you removed it? Could it be full of debris? Even a new system can have a surprising amount of when you first run gas through it. |
No it's not the 40. It has no decal. I'll check filter tonight.
Just FYI I had that 100 filter on my car for just a few 100 miles before all the new fuel line and tank and sensing unit upgrades because I wasn't sure if my old sock was any good. When I pulled the old sending unit the sock was in great shape. I just don't see how I could have filled up a 100 micron filter so fast. Before reinstalling with the new tank and sender. I could blow easily through the filter. And the car fell on its face in second gear first run.
Ok pulled the element out and did not look black or dirty.
I am not running a pre filter......never have....haven't killed a pump yet...knock on wood
Ideal? probably not........I don't have fuel delivery issues as witnessed by watching video of fuel pressure through the 1/4.....tank is not sumped....1/2 tank of fuel seems to do the trick...no less
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
Oh yeah I know its not ideal but will work I'm not that worried about it this point. Just tickled that my car pulls hard through all the gears
Hey Robb is it possible you guys put the wrong filter element in filter case?
From the factory all they had was a sock in the fuel tank and a filter in front of the carb and it worked pretty good.
Tim Corcoran |
Some kind of prefilter or sock needs to be used. We get several pumps back every year that aren't pumping correctly because one or more valves is being held open by a piece of debris stuck in a valve. |
My guess is that one of the two fittings on the filter was not sealing completely and was allowing air to be sucked into the system. Have you ever tried to suck a cola through a straw with a hole in the straw? |
but for some reason its not working. as far as the fittings sealing I have them on tight with thread sealer. Now I was running a 3/8 npt to 1/2 inch barb on the inlet and 3/8 barb on the out. If that makes a difference since I'm going from 1/2 inch sender to 3/8 fuel line. No way I'm making over 450 horse.
Well, I'm stumped. Maybe the pump is not working 100% right. When you don't need the pump for a week, ship it to us and we'll flow it and examine it internally.
James, the guys at RobbMc will fall over backward to take care of you.
X2!!
X3! Even when its operator error!
