App for Instantaneous MPH?
I'm going to need an iPhone app that tells instantaneous MPH. My '75 Formula project car is going to have different tires and gears; so I'm positive that I'm going to have to recalibrate the speedo. Thoughts?
Oh, and it doesn't have to be free but modest price and works great would be the goal. Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” Last edited by Elarson; 02-26-2022 at 09:01 AM. |
I just open up Google maps whenever I want to verify my speedometer….it displays the speed you are going.
The Following User Says Thank You to ID67goat For This Useful Post: | ||
Anyone you know with an old gps? lika a garmin etc..
72 Luxury Lemans nicely optioned |
You can get a GPS speedometer. Then it wouldn’t matter what ratio or tire size you are using.
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
The Following User Says Thank You to TransAm400 For This Useful Post: | ||
x2. google maps uses GPS & displays real time MPH. also shows speed limit for the area you are in & shows speed cameras which i really like since they pop up secretly all around my city or others i travel to that im not familiar with. & its free.
i used 2 different speed apps , downloaded from google app store for free.
worked fine
67 gto 400/400/3.90(sold) 69 lemans vert 400/400/2.78 89 trans am 350/700r/3.27 67 lemans custom |
Speed Box , free app
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
Life 360 on your phone. You can see what mph anyone n your group is going like your kids going 85 down the freeway!
I just use Google Maps. It's free, good, and provides real-time traffic conditions. It displays the posted speed limit as well as your actual speed.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
I use GPS Test for my Android. Not sure on Iphone. Its free and great to use. Used it to calibrate all my vehicles.
They're just TRYING to keep up with traffic at 85 down there.
Near where you are that is for sure the speed limit! I can remember in college when they dropped it to 55 it took longer to get from College Station to Dallas as it does to get to Dallas from Houston now! The DPS boys still hang out in about the same spots.
I have one for my iPhone called smart gps speedometer that’s free. Phone vertical and it’s “analog” looking, sideways and it’s digital. It works pretty well but there seem to be plenty if you search the App Store including many that were there before when I downloaded mine.
1977 Trans Am 400/4speed (swap) Brian |
I have an android phone and used DigiHUD quite a bit in the past. GPS speedos are all the rage now, probably a better but pricier option.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
If you do a 4L80E swap into an older car, the 4L80e has no provisions for any speedometer other than a electronic pickup. I was going to use a GPS speedometer in my next street project with a 4L80E transmission.
Last thing I want is Google knowing how fast I'm going and where.
DragStarLeMans |
The Following User Says Thank You to Drag Star Le Mans For This Useful Post: | ||
Truth be told, there could be a good chance it already knows lol.
Is the phone in your pocket Android? Guess who owns Android?
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Lol, yep! And honestly, it doesn't matter if you're using an Android or iPhone based smartphone, or if you have a mapping app installed. You are traceable and your data is being logged by cell phone companies even if you just have a "dumb-phone" (i.e., non-smartphone) via cell tower triangulation.
https://www.ebay.com/itm/223572746538 https://www.ebay.com/itm/224094971911
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
