Old 07-26-2021, 05:43 PM
Formulajones's Avatar
Originally Posted by 1965gp View Post
Took it to pick up my daughter from cheer practice this evening. About 15 miles round trip? Car got up to about 195 but on the open roads at 50-55 the temp didn’t drop at all. Not once. I’m thinking that (as others have said) the shroud definitely restricts the natural air flow
Yep, that's exactly what I expected you would see.
It's unfortunate because the dual electric fan setup is such a clean looking piece when installed, frees up a little HP and frees up space in the engine compartment. But....if it's not doing the job it's gotta go.
There are some really good dual electric fan setups on the market that work as intended, they get a little spendy though. But after I swapped dad's car over to his factory shroud and clutch fan, and the temps immediately dropped 20-25 degrees, he had no more interest in experimenting with electric fans and decided to leave the car well enough alone.
https://youtu.be/XqEydRRRwqE
  #42
Old 07-26-2021, 05:52 PM
padgett's Avatar
padgett padgett is offline
Should ask if you have the stock 195F thermostat ? Personally I use 160F in non computer cars and 180F in computer cars. Also like fast opening Stant Superstats & reprogram computer cars for fans to start at 182F and be all in by 190F.
Web Site
  #43
Old 07-27-2021, 09:38 AM
Mike Fowke Mike Fowke is offline
1965gp - If you need to (or want to) run electric fans and have the budget consider having a shroud made. If you can produce accurate drawings and measurements, finding a local fab shop that can do it for a reasonable price shouldn't be too hard.
I have a Cold Case radiator and was running a OEM dual fan with a Derale controller. The OEM shroud sat on the core and blocked more air than it moved, and I experienced the same results as you. I had a custom shroud made that is 1" deep, covers and seals the entire core, and I put two 12" Spals on it. I auto-crossed the car a couple of weeks ago in low to mid 90 degree weather, and it never went over 180 at the water crossover. It barely gets there in normal driving (city or highway) on the hottest days.
180 degree thermostat
cast water pump impeller - clearanced to divider plate
no AC
ported vacuum
  #44
Old 07-27-2021, 09:56 AM
roger1's Avatar
roger1 roger1 is offline
Ledfoot Racing makes one for dual 14" fans for a '70 GTO.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #45
Old 07-27-2021, 12:05 PM
1965gp 1965gp is offline
Thanks guys- I am leaving this week for Norwalk but within the next week I should have it swapped over to a factory fan set up. I don’t need or really even want to have electric fans on it- I actually thought it would be better but with the shroud design it’s proving that isn’t the case
  #46
Old 07-28-2021, 11:17 AM
Bandit400 Bandit400 is offline
I may be late to the party here, but I had the same experience with the cold case radiator/electric fans/shroud. Beautiful looking piece, and gave me a bunch more room under the hood. But it would not keep the car cool no matter what I did. So I dumped the electric fans/shroud and went back to a clutch fan and it cooled right back down. On a related note, I have a full fan/shroud/controller setup for sale!
  #47
Old 07-28-2021, 12:56 PM
I should note that in regards to my comment above, I have the Cold Case radiator still installed, and it is awesome. I just ditched their fans.
  #48
Old 07-28-2021, 01:19 PM
torqhead's Avatar
torqhead torqhead is offline
Hey Larry,
I've completed my testing with the 2 row cold case that I told you I was swapping in for the defective 4 core aluminum. Using the flex-a-lite's is not an issue and runs just as cool as the 4 core aluminum. Now when your dad see's this, I know he's a power junky, he has the option to use the flex-a-lite's like we talked about. Yeah, I know, I probably just gave you another project to do.... now get that car painted so you can help your old man out... lol
  #49
Old 07-28-2021, 01:27 PM
roger1's Avatar
If the Flexalite shroud mounts directly to the core with the plastic ties, that's a deal breaker for me. I think the vibration reduces the life of the radiator.
  #50
Old 07-28-2021, 01:42 PM
ZeGermanHam's Avatar
And mounting that way also dramatically reduces the surface area with which air is pulled through the radiator. Any area of the radiator that is not directly underneath the fan will not have air pulled through when moving at slower speeds.
1998 BMW 328is (track rat)
  #51
torqhead's Avatar
It does not mount to the radiator with plastic ties.
  #52
Old 07-28-2021, 02:21 PM
Originally Posted by torqhead View Post
Hey Larry,
Holy Cow someone delete this post before dad sees it !!
Just what I need is more work to do
Sounds like it worked out for you
I'll email you some pics of current progress
  #53
Old 07-28-2021, 02:23 PM
torqhead's Avatar
Getting the right size assembly for your particular radiator is important. The flex-a-lite's I've used are the ones that have porting in the chassis of the fan assembly. For slow speed the flaps close, although I would challenge anyone to think you'd pull air obviously in that area but it doesn't matter as the fan(s) surface area covers most of the radiator and should be more than sufficient to keep the car cool. Needless to say if it doesn't more than likely there's a different issue such as too small or clogged radiator, water pump plate with extreme gap, etc.
  #54
Old 07-28-2021, 02:25 PM
torqhead's Avatar
LOL, you're just part of my amusement today., I'm sure you'll return the favor somehow!
  #55
Old 07-28-2021, 02:29 PM
  #56
Old 07-28-2021, 02:50 PM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Hmmm, have to check this out. I need some pics.
  #57
Old 07-28-2021, 03:27 PM
David Jones's Avatar
Factory radiator and shroud. 7 blade factory fan with an HD clutch. 180 degree Stant SuperStat. The 455 stays within a few degrees +- of the thermostat's rating.
I also drill a couple of small holes in the stat for filling ease.
I ran a colder (160?) thermostat a while back (years) and the engine bay always seemed oddly cool when I opened the hood.
  #58
Old 07-28-2021, 03:49 PM
torqhead's Avatar
Your son has pics on his phone, guess he's been holding out for months... lol
  #59
Old 07-28-2021, 03:55 PM
GTO JONES's Avatar
Well, I'll have to have a talk with him. LOL.
  #60
Old 07-28-2021, 03:56 PM
Oh great, cats out of the bag now
