Old 09-15-2021, 04:43 PM
Originally Posted by 68ragtop View Post
For whatever reason I never got a notification of the additional posts on this thread until Greg posted. My insulator tube has a tab that secures it to the the head bolt stud that the heat shield is also fastened too. Like Greg mention though, if you have the R/A manifolds I believe you have to go underneath .
Are you using Tapatalk by any chance?
Sent from my moto g stylus (2021) using Tapatalk
Old 09-15-2021, 07:07 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
No I am not, but I always get that page landing if I click the link from my phone. most of my posts are when I am home, or work computer once in a while.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
  #63
Old 09-15-2021, 09:50 PM
I know that l'm probably not using it correctly but I never seem to get notifications from threads that l participated in using Tapatalk.
Old 03-28-2022, 05:52 AM
dataway's Avatar
dataway dataway is offline
Resurrecting this thread for a moment.
After perusing all the posts, I'm still a bit confused.
If you guys were ordering a set of non-correct 2 ga. battery cables from the "Extreme Battery Cable" guys ... what lengths would you order for a 68 if you want to use the RA cable routing? (down by oil pan)
From reading this thread I came up with NEG - 27"
But I'm not clear on the POS length.
  #65
Old 03-28-2022, 12:21 PM
Verdoro 68's Avatar
The positive cable on my car, minus the connectors, is 41". 43" with the connectors.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
  #66
Old 03-28-2022, 12:56 PM
Mine is about 50 to 55 in. Best estimate with it being installed. I think I mentioned before that I made mine a little longer so that when I drop the starter it gives me some slack and also because of the somewhat circuitous route I took to get it back there.
Cut yourself a piece of 14 gauge, run it where you want it then see how long it is.
  #67
Old 03-28-2022, 01:03 PM
dataway's Avatar
The reproduction positive I have on mine now is 43" center to center ... it appeared that with a quick test that I could still run it underneath and have enough length ... in fact I think going underneath is actually a shorter route.
The reason I ask rather than just measuring and having one made is that I thought maybe if I get it the OEM length I'd have the option to run it on the RA low road .. or the correct high road route for my non RA car.
  #68
Old 03-28-2022, 05:04 PM
vertigto's Avatar
vertigto vertigto is offline
M&H told me that their repro RA cables measure:
  • Negative = 27"
  • Positive = 42"
FWIW...I bought 1 gauge versions of both from batterycablesusa.com for a total of $40.81 (including shipping).
  #69
Old 03-28-2022, 05:21 PM
dataway's Avatar
Excellent ... I think that will work for me.
Yep ... same place that sells the extreme cables ... can't beat their prices. I like correct but jeez, the price you pay for that spring ring terminal on the repop cables is huge.
