How do they get blocks this clean!
As part of 4 previous engine builds, I used different machine shops for each. Each shop vatted the block and they all cleaned up fine. All of the blocks wound up with some traces/patches of rust staining on the outside. I’m not talking about flash rust that appeared on the block days after picking it up from the shop. This stuff was already there the day I picked these blocks up, so it appeared to be surface rust that was on the block but did not get removed by whatever method the shop used. Now, I compare my experience to what I see in every engine rebuild article in every car magazine I’ve ever seen. All the blocks in these articles are spotlessly clean and look like virgin cast iron. How is this look achieved? Shot peening? Some other product/process?
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
In the past I've had them put in a tumbler for lack of a better word, I think it used steel BB's and came out brand new. There is a name for the process that escapes me at the moment, someone will know.
The Following 2 Users Say Thank You to Formulajones For This Useful Post: | ||
Shot blasting
The Following 3 Users Say Thank You to Sirrotica For This Useful Post: | ||
steel abrading............the use of small steel balls to clean the cast iron with friction.
The Following User Says Thank You to JSuchma For This Useful Post: | ||
Thermal cleaner.... Heats the parts up and pelts it with steel shot.
The Following 4 Users Say Thank You to PAUL K For This Useful Post: | ||
Well there ya go, all kinds of names for it
The Following User Says Thank You to Formulajones For This Useful Post: | ||
If you wanted to do it yourself at home, get your 12 GA shotgun and a couple of cases of #4 steel shot! OH.......and a 6 pack of your favorite beer.
Uh, I don’t think so…
I can tell you how a guy I know tried to shoot a cast iron frying pan with a 12 gauge.
That didn't work out so well. I think beer was involved with that one too |
Lol... Not really. Tumbling is usually done with an abrasive material rotating in a drum, usually used for cleaning valves. Shot blasting is similar to shot peening but not controlled and won't remove grease, works great for cleaning rusty cranks and cast rods. Steel abrating is one of my favorite but won't work well on an oily block, the best process I've found for cleaning rusty parts like exhaust manifolds. Thermal cleaning heats up the block and is the only process mentioned that will remove rust, corrosion and sludge.... In short
Just trying to be informative. |
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
Seen the new Laser rust cleaning??? Prob not used on blocks, most are bathed, then put into a shot blasting cabinet with steel BB's. But man, the new Lase tech is wicked!
The Following User Says Thank You to zippy For This Useful Post: | ||
The process per Post #17 is fantastic, making the old Pontiac castings look real good.
Nah, chopped wire has sharp edges, which requires more machining, especially an Aling hone, which should be avoided. Steel shot is round, and blocks don't require the extra machine work. So method similar, Media is Not.
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
A long time ago (50 years?) a friend hand-ground and polished the outside of a Pontiac V8 block and heads ('58?) to a mirror finish, for a GMC-blown T-bucket on the show circuit. If I remember right (?) he didn't coat it with anything other than paste wax, since it almost never was run.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
It is pretty incredible to see the transformation. Here is the '68 400ci block that I will be building and installing in my '66 after I have shaken out the bugs for a year or two with the current running engine.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
The Following 2 Users Say Thank You to ZeGermanHam For This Useful Post: | ||
butler uses a tumbler of sorts. what about electrolysis?
It works, but it may take a few days to get it really clean. Then you have hydrogen gas to contend with.
I used to have a 55 gallon drum 3/4 full of used carb cleaner that the local carb rebuilder wanted to get rid of, that works well, but again it takes a few days to work. You need to pull the parts out and agitate it periodically. It would cost too much if you had to buy carb cleaner, mine was free. |
The Following 2 Users Say Thank You to Sirrotica For This Useful Post: | ||
Yeah that's not going to be a viable option for a machine shop. They generally don't have several days to wait for a clean block. Time is money for them, and then we all know how people complain if their stuff isn't done when they think it should be LOL
The Following 2 Users Say Thank You to hurryinhoosier62 For This Useful Post: | ||
