Old 01-19-2015, 07:11 PM
jcruz's Avatar
jcruz jcruz is offline
Default Pitman arm for 1969 Firebird
I thought these were fairly common, but apparently not!
Please get it touch if you have one for sale. 1969 Firebird. PM me or send an email to john.creuziger@cruzeware.com
I'm changing over from manual to power steering and need the pitman arm.
Thanks,
John
69 Firebird/TA clone
Old 01-20-2015, 09:16 AM
Sport69 Sport69 is offline
Try these guys. A lot of times if they don't have it they can get it.
http://www.frankspontiacparts.com/en...ngineparts.htm
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 01-20-2015, 11:54 AM
jcruz's Avatar
Thanks! Will try them if nothing shows up here...
Old 01-20-2015, 02:51 PM
jcruz's Avatar
Checked with Frank's....struck out.
Gotta be one out there!
Old 01-21-2015, 11:29 AM
Try this:
Performance Years Part # RFU-213B
You may have to switch out your Center Link too.
Old 01-22-2015, 12:59 AM
GStage1's Avatar
GStage1 GStage1 is offline
1969-74 Nova is the same????
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 01-22-2015, 10:23 AM
jcruz's Avatar
Try this:
Will give this a try. Listed as out of stock, so we'll see...
Thanks!
Old 01-22-2015, 10:33 AM
jcruz's Avatar
Try this:
No good -- order rejected because not in stock
I'll check the Nova compatibility....
Old 01-23-2015, 07:32 PM
461bird 461bird is offline
I have this pitman arm, sent you an e-mail.
Old 01-23-2015, 09:29 PM
jcruz's Avatar
Received! I'll get back with you tomorrow....
Old 07-15-2015, 05:51 PM
jcruz's Avatar
Well, I'm still looking for this elusive pitman arm!
461bird offered a swap for my manual setup but I'm keeping that.
Anyone out there with one to sell? Same contact info...pm me or shoot me an email at john.creuziger@cruzeware.com
Thanks,
John
Old 07-16-2015, 12:58 AM
kevin.1 kevin.1 is offline
Have you looked into a '69 Camaro pitman arm:
http://www.summitracing.com/search/y...1%2B4294947064
Not sure it's same for Firebird.... if it's different (between 'bird & camaro), then you could consider swapping over the entire steering linkage to Camaro to insure compatible parts. Probably costs less than 150 bucks for a complete, new Camaro setup.
I thought about doing this 10 yrs ago for my '69 Firebird... I needed an idler arm and NOBODY offered a new one. Some time later, a company called "Rare Parts" offered it for $150. I was shocked... almost swapped everything to Camaro since it was cheaper than the single firebird idler arm... but then bit the bullet and paid for the "Rare" part. I kick myself for not swapping to Camaro parts back then... especially with the thought of needing another Firebird piece (since I still drive the car a lot, including Hot Rod Power Tour).
Good Luck!
Old 07-16-2015, 07:55 AM
jcruz's Avatar
Good Luck!
Sound advice and it looks like I may be going down the Camaro path in the end...
What would I need beyond the pitman arm? New center link, I'm sure. Anything else?
Thanks!
Old 08-02-2015, 03:59 PM
max 93 max 93 is online now
Is the 69 the same as the 68 pitman arm ?
Old 08-02-2015, 05:47 PM
ra96's Avatar
ra96 ra96 is offline
If you swap to 68 camaro or firebird
youll need to change pitman arm -idler arm center link and inner and outer tie rods
68 birds and camaros used the same center link not sure 100% on the other stuff though
that 69 pitman is a tuff one to find for sure
Old 09-22-2015, 10:05 AM
bluegoose66 bluegoose66 is offline
Default pitman arm
I have a 67 gearbox with pitman arm. Will that work. Also have the rest of the linkage if needed.
Old 09-22-2015, 10:25 AM
Scott Thelander's Avatar
Default Hi
are you looking for the 69 only curved Firebird pitman arm
part number 7806616 ??
for power steering
I have a sweet one if so
Scott
Old 09-22-2015, 04:08 PM
Why are you changing the pitman arm?? When i went from std. steering to power steering all I changed was the steering box & put the arm on that was on the std box & it worked just fine , no problems at all. Ran the hoses & worked the way it should have . I didn't change the pitman arm, this was on a 68 conv. bird. >
Old 09-22-2015, 04:47 PM
Red face
Original'60's and '70's GM PS pitman arms had a larger splined hole than same application manual steering pitman arm, that is why JCruz is looking for a '69 Bird PS pitman arm #7806617
When did you have your Firebird, Rex?
Old 09-24-2015, 06:28 PM
Default pitman 7806616
pictures of a spare, possible 69, Firebird power steering pitman arm..
taken yesterday 9-23-15 ......... it was in a box with a complete 69 Bird
Hurst shifter and clutch/brake pedals ..and 69 rear bumper brackets,\
that just came out of a ,take everything in the shed, purchase...last week
Scott
ID:	408916   Click image for larger version
ID:	408917   Click image for larger version
