The insulating/deadening materials mentioned only add maybe 5/16" extra height which is fine with the jute-backed carpets such as ACC. No problems in my three cars, but I did have to remove some jute from the pocket around the bottom of the accelerator to restore full travel.
Les Iden ---------------------------- '65 Buick Sport Wagon Custom, 340, T350, 3:23 '66 GTO Post/468, 700R4, 3.31 (Mike's as of 9-16) '68 Grand Prix/455, dual AFBs, T400, 2:93 posi (sold) '72 TA tribute/461, T400, 3.08, (Russ's as of 9-16) '97 Mitsubishi Eclipse Spyder Turbo, Konis, 5 speed '09 Torrent GXP, nav, Sun & Sound pkg., Bilsteins |
That was my experience Les, right at that corner/point where the floor, tunnel, and firewall meet. I had to wrestle the mat to get it to actually stick down there in that corner, making several cuts, and even heated it a little. I worked it enough to where I didn't have to remove any jute though.
That reminds me that my second regret is I didn't run the stuff all the way up the firewall on the inside.
I already had my dash all asembled and the molded insulator pad in. |
Anyone ever weigh different versions of this aftermarket matting?
I only need something that is light & knocks down some of the heat coming up from the head pipes. In other words, over the hump & the first foot & a half of the toe pans & front floorpans.
Thanks guys. When I put the carpet in the '71 a few years ago I was given two rolls of material to use, forget the name of it. Anyway, it worked well enough, but the stuff is really thick and there are some spots that bug me because I just can't get the carpet to sit right. Time to yank it all up and start over.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg |
Anyone know about or use extream Dynamat?
Thanks in Advance.
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/245@.05 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft. |
Drown issues...
On your question, you will have a better chance at reducing/eliminating drown/cabin resonance by adding two tube shaped mufflers into the tailpipes, if possible. My Grand Prix had this problem which persisted through three different sets of long case mufflers and RamMat under the rugs until I added two cherry bomb style straight thru resonators in the tailpipes . Think of the exhaust system as a long tuning fork that can often cause this type of problem no matter how well it's suspended or isolated. Adding the extra weight in the tailpipes often cures your problem w/o spending $$ for more insulation or other testing other muffs.
These mats only really control vibrational resonance and they can be effective with only 80% coverage. They don't control a whole lot with thermal insulation. I still had heat coming through the floor on my car and still contemplate putting in some kind of heat blanket. http://store.secondskinaudio.com/ |
I'm using one layer each of RAAMmat and Ensolite in my Formula. Pretty reasonably priced compared to Dynamat and tested very well. Here is their website:http://www.raamaudio.com/categories/...Foam-Products/
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
For heat I used the horse hair type carpet padding used in your house. and put it over the whole floor I also glued it to the under side of center console, it stopped all the heat I just cut it to the size I needed sprayed it with spray adheasive and put it down it is working great-----BOB
My vert does not drone with my home made x-pipe. A trick I have used on other cars is to clamp a piece of small angle iron to the head pipes. This will determine if its the pipe. They them can be permanently clamped or welded. Or better yet, place a resonator at this location.
If you have metal to metal contact, thats gonna be hard to stop. Anyone ever use any of the spray in products like lizard skin? Dave
'68 Bird Vert, 455 , 6x-8, 1.5 HS, HEI, PPR TC-02-HF, TH400, 2500 Hughes, 2.56 8.2 (getting swapped for second gen with shorter gears) Fishing guide in the Washington state for Salmon, Steelhead and Sturgeon. Fish-On! |
www.bowhanger.com 468 poncho powered 66 cutlass 77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html |
When is the last time you held up some ACC carpet to the light? Kind of like spray on hair
Another satisfied user.....
I have the Goerlich's on the driver, all OE padding, and only WOT is what I would say is 'loud', totally acceptable IMO. And they have such a unique sound, really like them.
Getting ready to go through the driver's interior, will be doing all the mat, so am taking notes on this thread... .
#38
#39
Try R-blocks, through Amazon.Works great and is really cheap.
#40
Dave "Big Injun" Anderson dave@4mypontiac.com www.4mypontiac.com For GTO Celebration items click the tile coaster. |
