Old 09-23-2021, 06:12 PM
Vettdr Vettdr is offline
Default Hood hinge spring
Does anyone have experience replacing the springs on hood hinges? I bought new hinges from our sponsor and they came through without the springs. The springs on my old hinges are fine and they hold the hood open wide. I just want to take them off the old hinges without loosing an eye or a limb.
Old 09-23-2021, 07:17 PM
gtorich gtorich is offline
Vettdr..............if the old springs are still on the car.............all i used to get my springs out was an old alt/fan belt...........didnt have to pull too hard to get the spring out. Hook one end on the spring and give it a pull.
Rich
Old 09-23-2021, 07:31 PM
Check out some you tube vids they have a few different ways that you could try.........i did mine like the guy with the chains, just used a belt instead.
Rich
Old 09-23-2021, 08:47 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
I have a special tool for replacing the springs, I think it is made by K-D tools or Lisle. I have also just pulled them by hand and taken them off. All depends on how strong the spring is.
Old 09-23-2021, 10:09 PM
ZeGermanHam's Avatar
I had to get a little creative when installing the hood hinge springs on my car. I was unable to pull them far enough with a belt or similar using arm strength, so I ended up using a ratchet strap that I hooked to something high up on the wall that wasn't going to budge. That way I could slowly pull the spring far enough, click by click, until it was extended far enough to position correctly on the hinge.
1998 BMW 328is (track rat)
Old 09-23-2021, 10:17 PM
Thanks to all who replied. Your advice helped and I got the job done.
MUSLCAH MUSLCAH is offline
I just put some on a 67 Camaro….used a big screwdriver to slide them on….they came off by hand. Or as others have said
