SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
INNOVATIVE LM-1 Wideband 02 #3723
EBAY LISTING URL:
http://www.ebay.com/itm/281549681014...84.m1555.l2649 Slightly used Innovative LM-1 wideband 02 meter, perfect working condition, all docs, accessories, software, and original box. The default go-to for dialing a carb in for peak performance, economy, and efficiency! Description for another retailer: Finally, there's a tool that carburetor and fuel injection fans can share--Innovative Technology's LM-1 wideband air/fuel ratio monitors. The fully digital monitors take the guesswork out of tuning by delivering the exact air/fuel ratio instead of just reading rich or lean, and they're self-calibrating to give you accurate readings. The LM-1s measure data 12 times per second for up to 44 minutes. The data can be downloaded to a PC with the included serial cable and software so you can graph multiple sessions. Instead of spending hours tweaking and tuning your carburetor, use the LM-1s to get the information you need, tune your carb, and be done. Tuning a fuel injection system involves many variables, but the optional auxiliary-input cable provides up to 5 simultaneous readings, for a more complete view of an engine system's performance. For example, you can measure and graph specific air/fuel ratios in relation to rpm, MAF, MAP, TPI, and more. The LM-1 kits include a Bosch wide-band oxygen sensor and cable, cigarette lighter power adapter, serial cable for PC, 9 V battery, exhaust bung and plug, quick-start guide, and a CD with software and manual. *************FREE SHIPPING************LOWER US 48 ONLY****************** .
Start price is $125 buy it now $165
Ended early? 125.00 final price.Good deal
72 Luxury Lemans nicely optioned |
Yes, sorry, sold, to a member on here, I usually give preference to folks here.
Thanks for ending it early Mike and saving me some cash! I look forward to playing with it once my engine is back in the car.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
hey grivera if you ever sell it when you're done let me know!!!
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane |
Will do
