Old 12-14-2022, 01:14 AM
64speed's Avatar
64speed 64speed is offline
Default Home built rides
I am curious about home built rides. I want to pat myself and you guys with them on the back. What was supposed to be a quick freshen up and paint turned into a frame off for me starting 7 years ago. Here is the thing though, I am a shade tree at best, with that being said I have done every damn bit of my car except the parts that are obviously specialties. I farmed out the paint glass and AC and will farm out the hard parts of the interior but otherwise I have done every damn bit of this car in a two car garage with only tools I had or bought on the way for specific purposes. My car is amateur at best but I’m proud. Let me see yours!
ID:	603526   Click image for larger version
ID:	603527   Click image for larger version
The Following 3 Users Say Thank You to 64speed For This Useful Post:
Old 12-14-2022, 06:35 AM
chuckies76ta's Avatar
Wow, Car looks really nice.
Old 12-14-2022, 07:28 AM
Formulajones's Avatar
I build everything here in house for us and others.
Only thing I farm out is engine machine work. I do all my own engine, trans, and rear end building, paint, interior etc...
Congrats on all your hard work
https://youtu.be/XqEydRRRwqE
The Following 3 Users Say Thank You to Formulajones For This Useful Post:
Old 12-14-2022, 09:55 AM
PAUL K's Avatar
PAUL K PAUL K is online now
That's what the hobby is about.... Congratulations on seeing it through.
Go fast, see Elvis!
Old 12-14-2022, 10:27 AM
rtp rtp is offline
Tell us about the weels please
Old 12-14-2022, 10:43 AM
64speed's Avatar
They aren’t anything special, 18x8 Torq Thrust on all four corners.
Old 12-14-2022, 11:37 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice job! The 64 looks really good. I've done most of the work on mine as well, with the helping hands of my brother and a few friends. I did the paint/ body work and the engine assembly after the machine work was completed by a reputable shop. It adds to the "pride" value when you do as much as you can yourself.
ID:	603539   Click image for larger version
ID:	603540   Click image for larger version
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 12-14-2022, 12:20 PM
Singleton Singleton is offline
My 64 Lemans that I started in 2015 and recently finished. Done everything myself, by myself, with only two exceptions, the front windshield install and the rag top install. From welding-in floor pans, quarters, body work, paint, building engine, set-up rear end, interior, to mounting/balancing tires, alignment, etc, and finishing up last week with the vintage air system. Been a long road.
ID:	603546   Click image for larger version
66 GTO, 495, M22, Strange S-60 w/4.10
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 12-14-2022, 12:21 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Did mine at home in a 2 bay garage, body off, sandblasted the frame myself, ( won't do that again). rebuilt the trans M20, new bushing in suspension. Farmed out
the engine machining and paint. I put it back together after paint, scary. LOL.
Would I do it again, Probably, but cheaper to buy one already done. It's not perfect either, But it's a work in progress.
ID:	603542   Click image for larger version
ID:	603543   Click image for larger version
ID:	603545   Click image for larger version
ID:	603548   Click image for larger version
64 Lemans hardtop
4spd, buckets
Old 12-14-2022, 01:52 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
There's a certain amount of self pride when you've touched every nut and bolt
The Following 2 Users Say Thank You to 68WarDog For This Useful Post:
Old 12-14-2022, 02:07 PM
64speed's Avatar
Im waiting on my block to come back from the machine shop so I can put it back on the road ASAP! The block failure was caused from my stupidity so live and learn. I will be rolling around March with a much milder engine.
The Following User Says Thank You to 64speed For This Useful Post:
Old 12-14-2022, 02:50 PM
65madgoat's Avatar
Love the 1964! Great stuff.
This guy does all his work as well. Even painted his car show quality on his first ever paint job in his home garage! And takes the time to make videos of it all too.
Worth a follow:
https://www.youtube.com/c/FastMontysGarage/videos
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 12-14-2022, 03:39 PM
Verdoro 68's Avatar
30 years of DIY on my car. The number of folks who have worked on it besides me is in the single digits. Pretty sure I've touched every nut and bolt for better or worse. Made a lot of mistakes, but also learned a lot along way. I still feel like a neophyte in a lot of ways.
+1 Really like his channel. I watched it a lot when I started putting together my latest engine build.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 12-14-2022, 04:36 PM
1972 Goat herder's Avatar
1972 Goat herder 1972 Goat herder is offline
Here's mine. I bought it from a guy who "started the restoration" (translation - disassembled everything and threw all the parts into 36 large plastic totes). The fortunate part was that all of the critical pieces were there and it is completely numbers matching right down to the KR coded wheels. I farmed out the engine machining and had a friend do the final paint work. I did everything else.
ID:	603560   Click image for larger version
Name:	TA Front End.jpg
ID:	603561   Click image for larger version
Name:	Trans Am Shell.jpg
ID:	603562   Click image for larger version
ID:	603563   Click image for larger version
Old 12-14-2022, 05:02 PM
John Milner's Avatar
John Milner John Milner is offline
There are a few of mine. None are perfect by any stretch. But they are all good drivers that I fixed up myself. I love looking at and appreciating cars that have undergone a concours/show car restoration but I'm just not capable of that caliber of work nor can I afford it. But I do love old cars and Pontiacs so I just do the best that I can while having a good time with my family and friends.
ID:	603574   Click image for larger version
ID:	603575   Click image for larger version
ID:	603576   Click image for larger version
Name:	66 tempest.jpg
The Following 2 Users Say Thank You to John Milner For This Useful Post:
Old 12-14-2022, 07:31 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
Both of my Pontiacs are home built by me in a 2 car attached garage. Only work farmed out was engine machine work and building of transmissions. After a few failures, I’m now building my transmissions as well.
Lemans was a 17 year project with a lot of life going on in the middle. The ‘56 gasser was built in 2 years aided by Covid layoff and later retirement.
ID:	603580   Click image for larger version
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
Old 12-14-2022, 10:42 PM
I do like doing my own and knowing what I have. It's fun to talk to others when they ask who did certain things and you can say "I did".
I did everything on my frame off on my 72 Lemans vert in three years in my two car garage. Before that I did a 80 Fiat Spider vert. Before that a frame off on my 55 Chevy Sedan Delivery. Before that I did my 46 Willys Jeep. In the pic is also my 75 Camaro I bought in 78. I had someone else repaint it though in 2004. I started painting all my own cars after that.
ID:	603586   Click image for larger version
ID:	603587   Click image for larger version
ID:	603588   Click image for larger version
ID:	603589   Click image for larger version
Old 12-15-2022, 04:17 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
That verdoro green looks fantastic in that picture you posted of your car! it looks really nice!
1968 - Pontiac GTO
The Following User Says Thank You to Charlie Brengun For This Useful Post:
Old 12-15-2022, 09:06 AM
Half-Inch Stud's Avatar
Worst condition car i even bought, but got it done ( frame-off rebuild ) 3- years to the week. Used up the Prior decades of JY parts.
Old 12-15-2022, 09:24 AM
Bill Hanlon's Avatar
Bill Hanlon Bill Hanlon is online now
I remember the Hurst "His and Hers" shifters, but that picture carries it to the extreme.
