67 GTO fuel sender ground wire
good day, is there a proper location for the ground wire for the fuel level sensor at/near the tank?
https://www.facebook.com/KauffmanRac...6873234225938/ KRE 461,310 CFM 85cc, KB pistons, Eagle rods, Ohio crank KRE custom HR236,Dougs ceramic,Edelbrock Pro Flo 4. Quick Performance 9". 552HP 594 TQ |
I am not 100% sure mine is correct but the ground wire is secured to the trunk brace just in front of the passenger side tank strap. Sorry for the blurry picture. I just went out to he shop and crawled under my car with my cell phone. After a few guesses I got this shot.
Not sure if it's different between 1966 and 67 (or assembly plants), but on my Pontiac, MI built 66, the ground wire is on the driver side trunk brace. See attached photo from before my restoration began.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild Last edited by ZeGermanHam; 07-22-2021 at 12:50 AM. |
Pontiac definitely wasn't too worried about the sender ground and both photos are showing the correct location (although I would clean down to bare steel on the brace to insure that the wire is actually grounding). The big O-ring sealing the sender to the tank effectively isolates it and the ground wire is necessary for the sending unit to work.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
thank you gents, that helps!
