Old 11-17-2022, 12:40 AM
punkin punkin is offline
Default Wilwood vs Hydroboost
Hello all,
I sent a message out to a hydroboost supplier some time ago and shared with them that I had Wilwood calipers on the car. I was told this combination could work but "I will ask that you be mindful while stopping and stopped at a red light to not keep pushing down on the pedal because the booster will still be assisting in pressures and the Wilwood calipers are not cast and will expand and could bend or brake."
Anyone else heard this or have had issues? I did reach out to Wilwood but no response yet.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 11-17-2022, 02:12 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I run a Hydroboost system, but not with Wilwood. Can't see their calipers bending or breaking due to hydro boost pressure. Seems kinda weird.
Not like you would need added pressure while already stopped, so pressure would be minimal when stopped. Not sure who's hydro boost system your looking at
But I bought mine thru Hydratech, great to deal with. https://www.hydratechbraking.com
Im sure they would be able to help you on that question.
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 11-17-2022, 02:43 AM
65madgoat's Avatar
I had a hyroboost with Wilwood 6 piston brakes - no issues.
BUT -- I did not like it and went to manual brakes. Plus less junk under the hood to deal with and route etc. Many guys have issues with their power steering booster and reservoir quite often with hydroboost.
With brakes like Wilwood you can go bigger in rotors / calipers, getter better bite pads etc and not even know you don't have power assisted brakes.
I would never go back to hydroboost. Love my manual set up around town and on the track.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 11-17-2022, 10:05 AM
Thanks for the feedback guys. I don't want to post the company name, just don't think that would the right thing to do but it is a big name in the brake products distribution industry. Currently waiting to hear back from Wilwood.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-18-2022, 09:43 PM
I didn't want to be spreading misinformation and I did get a reply from Wilwood. It seems the comment made to me by the Hydroboost distributor is not entirely accurate. This from Wilwood:
Thank you for the inquiry with Wilwood Disc Brakes.
The calipers are forged not cast and we’ve had plenty of customers use hydroboost systems with our brakes and be just fine.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-19-2022, 01:07 PM
ZeGermanHam's Avatar
The comment by the hydroboost distributor also just doesn't make logical sense. If their concern was pedal pressure being too great and possibly breaking/deforming the caliper, the biggest risk of that happening would be under heavy braking, not while you are stopped at a light. I don't think there's any merit to their claim, and would follow Wilwood's guidance.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 11-20-2022, 08:35 PM
I too am surprised by the comment. This comes from a large name distributor of braking systems. I'm not expert but I too would have thought that the pressure would be greatest under hard or panic braking.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 11-23-2022, 07:52 PM
389 389 is offline
Yep 100% correct. I can make a brake hyd line or a wheel cyl. burst if I really stand on the brake pedal in my 2001 Chevrolet 3500 work truck.
The Following User Says Thank You to 389 For This Useful Post:
Old 11-24-2022, 11:06 AM
george kujanski's Avatar
Comment was made by a person who failed high school physics.
George
The Following User Says Thank You to george kujanski For This Useful Post:
Old 11-24-2022, 06:34 PM
76TA462 76TA462 is offline
Five summers now with a hydroboost (recommended by Wilwood) and conversion to Wilwood brakes (6 piston front, 4 piston rear). All good and very happy with improvement.
The Following User Says Thank You to 76TA462 For This Useful Post:
Old 11-23-2023, 12:32 PM
chuckies76ta's Avatar
chuckies76ta chuckies76ta is online now
Thanks to Punkin for the thread and those who have posted.
I just want to add info to this thread to verify Wildwood brakes and calipers. I just upgraded my rear drums to Wilwood forged calipers and their 11" rotor. I'm in the process of doing the front 11" rotor and calipers. We run Hydro-boost systems on both cars. Took the car out couple of weeks ago and was able to lock up all 4 wheels when stopping. Have the Wilwood D52 calipers on front and Wildwood calipers at the back. No issues with any of calipers. This is from Wilwood website.
Forged billet aluminum bodies, stainless steel pistons, and competition style high-temperature seals put an end to the rust, bore pitting, and seal failures that plague the OE caliper design. D52 calipers provide low-maintenance performance and a huge weight savings with high temperature reliability for the street and track.
Theses are the new rears. Forged Dynapro Low-Profile Pro-Series rear disc brake kits
My new fronts. Forged Dynalite Pro Series Front Brake Kit
I had my pressure gauge on the fronts to see what kinda pressure was on the calipers in the garage with engine running and was around 500-600 psi. I will be doing more pressure testing come this summer when system is all complete. FYI.
Old 11-24-2023, 12:37 PM
vertigto's Avatar
vertigto vertigto is offline
It would be good to know the manufacturer/supplier that provided that comment/information. Others may want to avoid or follow up themselves.
Old 11-24-2023, 01:52 PM
It would be good to know the manufacturer/supplier that provided that comment/information...
It really doesn't matter if it a company larger than 20 employees - once you get to a certain size technical expertise in customer service is diluted as those who answer phones/emails do not have the depth of experience for more arcane questions.
Old 11-28-2023, 08:29 AM
Thought I would post this link for anyone having issues with there Hydro-boost system. Really good info. https://www.pro-touring.com/archive/...p/t-86332.html
Never fill the Master cylinder too full, as the brake fluid has too return after applying the brakes. There is that, plus the heat expansion from the fluid.
(Heat expansion of the brake fluid) Never cross my mind.. There is always so many little things that one has to be aware of.
The Following User Says Thank You to chuckies76ta For This Useful Post:
