Old 09-06-2021, 03:38 PM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
Default Horn or Horns?
Recently picked up a very originall 67 GTO. Did the 67 GTO come with dual horns? Mine has just one and its not working.
TODD
Old 09-06-2021, 04:23 PM
Jeff Hamlin's Avatar
Dual Horns were standard on all models except Tempest.
Name:	1967 ACCESSORIES CATALOG (49).jpg
ID:	572592   Click image for larger version
Name:	1967 ACCESSORIES CATALOG (50).jpg
Old 09-06-2021, 05:19 PM
padgett's Avatar
padgett padgett is offline
I like air horns particularly for low cars.
Web Site
Old 10-01-2021, 01:06 PM
After investigating mine were not plugged in. Still not working maybe replace relay next.
TODD
Old 10-01-2021, 04:14 PM
fyrffytr1's Avatar
Unplug the hot wire at the horn and use a jumper from the battery to see if the horn works.
Old 10-07-2021, 02:46 AM
I definitely wouldn't replace the relay without testing the horns or the voltage to them...90% of the time it's the horns themselves. They can be repaired fairly easily by the way.
Old 10-07-2021, 11:52 AM
ZeGermanHam's Avatar
Greg, any chance you know of any resources/info for repairing the horns? My low-tone horn works but is buzzy. I've heard reference of a bolt that allows you to adjust the diaphragm, but I'm not sure if this is true. I'm assuming my diaphragm is rusted out.
1998 BMW 328is (track rat)
Old 10-07-2021, 12:26 PM
padgett's Avatar
There is a screw on the back of every electric horn I know. Just grabbed this one at random
Web Site
Old 10-07-2021, 12:32 PM
OG68 OG68 is offline
The Horn Works in Wisconsin. He has restored two sets of horns for me.
https://www.carhornrestoration.com/index.html
2007 Cadillac SRX
Old 10-07-2021, 12:38 PM
Thanks. I see that on my horns. Wasn't sure what it was. I'll give it a try.
Thanks. I'm more interested in a guide for repairing them myself and a place to buy parts rather than paying someone else.
Old 10-07-2021, 03:56 PM
Yes, there is a tutorial online somewhere. I'll have to try to remember where I saw it but it's basically drilling the rivets out, separating the halves and thoroughly cleaning everything inside. It won't look totally factory but it will look pretty good when you put nylon insert lock nuts and screws on it and paint everything.
You tune that screw using an amp meter in series.... But it's no good if the contact inside is all corroded. I'm sure I can find it but I'm posting this on my phone and I believe I have the information on my laptop.
The way they work is this.. there is a sheet metal diaphragm similar to a speaker cone with an electrical contact on it. There is a coil of wire near the cone.. when the horn relay applies voltage, the coil induces a magnetic field which pulls the cone and opens the contact. When the contact opens, the cone relaxes again and immediately makes contact again. This repeats at a high frequency over and over again causing a buzzing made by the sheet metal cone. The horn shape amplifies it. The adjustment screw allows you to tweak the mechanical movement of the cone to a sweet spot indicated by peaking the current draw.
If you drill the rivets out and take it apart you'll see how it works.
Old 10-07-2021, 05:09 PM
I found a short thread from back when I did mine. I was wrong about peakng the current totally. There is a sweet spot though.. you basically only peak it to the point where the volume/sound starts degrading, then back off a little.
https://forums.maxperformanceinc.com...highlight=Horn
Old 10-07-2021, 08:24 PM
Thanks Greg. Did you have to replace the diaphragm in your horns?
Old 10-07-2021, 08:36 PM
U47 U47 is offline
Irrelevant to the question. Pontiac doesn't have air horns.
Old 10-07-2021, 10:29 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
The information on a Window Sticker mentions “HORNS-DUAL” as standard equipment on a GTO.
Old 10-08-2021, 03:30 AM
No, l didn't have to replace anything except the rivet. Just clean the contact and all of the crud that winds up in them over time. Dirt, spiderwebs dead bugs, etc. It just needs to be able to move freely when it's exposed to the magnetic field.
Old 10-08-2021, 09:51 AM
1_Wild_Cat's Avatar
I have seen an online guide to restoring the horns. I think it was on a corvette site…they also had a source for rivets to put it back together as I recall.
Old 10-08-2021, 01:57 PM
I found an article that will suffice although it's not the exact article I used back then..He doesn't go into any detail about removing the rivets but I now recall that the ones in our horns are pretty heavy and swaged in place. I used a Dremel to grind the heads off IlRC...
http://www.secondchancegarage.com/public/198.cfm
This reminded me also that I forgot to mention that there is a gasket between the two covers. I used rtv and this guy and the original article that I used did the same.
