Old 04-21-2021, 02:04 PM
Verdoro 68's Avatar
Default Hidden headlight door alignment tabs
Sometimes I think Inline Tube makes stuff up. Are these little tabs factory? I don't think I've seen them in any factory diagram. They came with a headlight door screw kit and are supposed to keep your doors aligned with the grills by preventing the doors from closing too far. IDK, maybe they're like that small starter bracket that everyone threw away the first time they had to work on their car.
The tab in question is shown behind the screw in the upper left of the headlight door. Side note - the Parts Place reproduction headlight door covers are really nice!
ID:	565139   Click image for larger version
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
The Following 4 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 04-21-2021, 02:31 PM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
My car had them when I bought it in 1971. As stated they usually got lost the first time somebody worked on the headlamp doors. You have to have them if you want the grills to line up properly.
The Following User Says Thank You to gtohurstjudge For This Useful Post:
Old 04-21-2021, 03:39 PM
Verdoro 68's Avatar
Somehow I've managed to get my doors lined up without them for the last 30 years. Guess I'm lucky or maybe they could be even better aligned. Anyway, they're on the car now.
I do appreciate Inline recreating this stuff that was lost to time. I also picked up a reproduction vacuum modulator line bracket that hangs off a bellhousing bolt that I could never find otherwise.
Ken
Old 04-22-2021, 12:02 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Think that's the first time I've ever seen those lil critters. Glad to hear the covers are of good quality.
Although not too often, I do get surprised with unrecognizable things getting reproduced.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 04-22-2021, 11:03 AM
I've never seen those either. I think mine line up pretty well without them but might be worthwhile for absolute perfection..
Old 04-22-2021, 06:03 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Speaking of "no see ums"... How many of you have ever found the original wavy spring washer that was installed between your valve cover bolt and the valve cover in 1968? I have a complete original engine, built 12/67 that still has them. I bet they nearly all were lost upon first service.
They look like this and can be found at most of your local HW stores in the washer/bolt section
Name:	wavy washer gto.jpg
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
The Following User Says Thank You to 68gtoMN For This Useful Post:
Old 04-22-2021, 06:57 PM
Verdoro 68's Avatar
That's another new one to me. I'm sure those guys were a staple in post-rebuild coffee cans filled with leftover hardware in the '70s.
Ken
Old 04-23-2021, 11:32 AM
Gastiresandoil's Avatar
Never found them, but have since replaced them.
Old 04-25-2021, 11:14 AM
Mark Simiele's Avatar
Mark Simiele Mark Simiele is offline
In the picture, they are just visible on the top correct?
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming.
67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project.
Old 04-25-2021, 11:34 AM
4zpeed's Avatar
Yes, visible above the top left phillips head screw, one per door.
Frank
Old 04-25-2021, 02:37 PM
tekheavy's Avatar
tekheavy tekheavy is offline
I definitely never seen those on my doors. What are they actually doing to keep the doors aligned? Are they just acting as spacers?
Old 04-25-2021, 03:18 PM
Very interesting, thank you and I need to look at my car to see if they are are.
Old 05-04-2021, 02:02 AM
68gtoMN's Avatar
Was over at a buddy's place last night and examined a completely original Endura bumper setup with hidden headlights. The covers have the tabs installed on them. This bumper had never been off the original car until it was pulled by my buddy. I never knew about these before - I'm going to need to look at a couple of my setups closer now!
'70 LeMans Sport
Facebook Event
The Following 2 Users Say Thank You to 68gtoMN For This Useful Post:
Old 05-04-2021, 08:10 AM
Yeah, I noticed my headlight doors ARE slightly elevated. Any chance we could get measurements for the tabs and a pic of how they mount?
Nevermind the mounting method...Frank's pic shows that pretty well.
ID:	565897   Click image for larger version
Old 05-04-2021, 10:10 AM
gtohunter's Avatar
gtohunter gtohunter is offline
Default .
I don't have the tabs, but I'll live with it.
Jimmy M
68 GTO
Old 05-05-2021, 07:14 AM
4zpeed's Avatar
Show off..., it does look good though
To be honest, all the info is right in the first post, c'mon guys, give it up for Ken, gotta start hitt'in that thanks button an chit, this was one of those, well I'll be dam threads.
"If", we had thought about it, and used those without knowing they were factory installed, it would have been a bit iffy as to just how tacky that might appear, right?
The plus is they perform a function that many need but didn't realize they had the option to use, now everyone can use them without copious amounts of shame.
Thanks Ken,
Frank
The Following 2 Users Say Thank You to 4zpeed For This Useful Post:
Old 05-05-2021, 01:49 PM
Verdoro 68's Avatar
Ha - you know, the hokey-ness of the solution was my initial reason for posting. It was like "Could this really be factory?!" I guess I had the same reaction to the chicken wire cowl screen and the coffee can vacuum reservoir. Good old '60s "technology".
Here's some more specific pics. They're 1/2" x 1" in size.
ID:	565969   Click image for larger version
ID:	565970   Click image for larger version
Ken
The Following 3 Users Say Thank You to Verdoro 68 For This Useful Post:
Old 05-05-2021, 01:58 PM
I've had a few in a coffee can of GTO "bits" for years. Now I know what they are!
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 05-06-2021, 07:42 PM
There is another part that got unceremoniously lost on these cars back in the 70's when the timing chains were being done......the two spacers that go in the holes in the bottom of the timing cover that center the cover exactly on the crank so that the front seal seals as it should. I never tear down a Pontiac v-8 that has both of them there.
Old 05-06-2021, 09:58 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
I still have the original door adjusters on my 68, however mine have a 90 degree bend that makes them L shaped at the tip where it contacts the bumper. They are not flat like the inline tube pieces. Maybe they were only added to cars that needed them after assembly? I had them on both sides & still do.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
The Following 2 Users Say Thank You to 68ragtop For This Useful Post:
