Old 07-24-2021, 09:08 PM
1965gp 1965gp is offline
Default What is a decent temp?
I just put a cold case radiator and 12” fans in my 70 GTO. Extremely happy with the product, this is the second rad I have ordered from them.
Here is my question- what temp are you happy with driving around?
As a test to see how it did I took it out today since it was 95 and I went through a chick fil a drive through. I figured that would be a great test for it.
Quickly went to 180/190 then when I sat in the drive through it got to about 205, 210 by the time I was done. Drove a few miles home and it stayed at 210.
I guess since it didn’t go down on the drive home with additional flow I should expect it to peak around 210.
Being that I live in Houston I have the fans wired up to be on with the ignition. At a humid 95 deg I’m pretty happy with 210 in a drive through.
What are your thoughts?
Old 07-24-2021, 09:17 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
Mine stays at 185 or less here in south Louisiana with the A/C on. 175 or less without A/C. 160 thermostat in a 463 cube. Cold Case with 19" clutch fan.
Old 07-24-2021, 09:28 PM
Tom Vaught's Avatar
Boost Engineer
a 160 T-Stat for me with two 1/8" holes in the ring to get rid of trapped air.
Tom V.
Old 07-24-2021, 09:45 PM
GTOGEORGE's Avatar
I’m thinking at 95 your good, that’s about what my wife’s blown ta runs at.
GTO George
Old 07-24-2021, 10:08 PM
I may swap out the thermostat with one that has some holes drilled in it.
Thanks for the input.
How do you get your car to keep running at 175? That seems very cool in southern LA?
Old 07-24-2021, 10:53 PM
MUSLCAH MUSLCAH is offline
Tom V.
Got a pic of that… sounds good !
Old 07-24-2021, 11:01 PM
ZeGermanHam's Avatar
Those temps aren't wildly out of what I'd expect to see while idling in 95F ambient weather, but it would be nice to see the water temp come down to under 200F once you got moving again. I generally don't like electric fans, though. Probably about 95% of the time I see people installing them in such a way that at best they won't make any cooling improvements over a properly set up clutch fan + shroud, and at worst they actually hurt cooling performance.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
Old 07-25-2021, 12:28 AM
GTO JONES's Avatar
GTO JONES GTO JONES is offline
Get rid of the cold case shroud and fans, the radiator with 1 1/4" tube is great. I went through the same thing, put the stock shroud and a clutch fan back on. I have 571 cu in Pontiac and run a 160 thermostat there shroud is flat against the radiator and fans can't move enough air. I was running 190 to 200 + put the stock shroud and I think its a 19" hd clutch fan back on and now its 165 to 175.
The Following 4 Users Say Thank You to GTO JONES For This Useful Post:
Old 07-25-2021, 01:51 AM
Scott65's Avatar
Scott65 Scott65 is offline
Short answer, I think you won't hurt anything at 210. All the modern cars run over 200 it seems, and they achieve long life. Also being in Houston, I understand your concerns. Mine won't top 194, and most of the time stays below 187. I went to a 170 degree thermostat so that in the winter it doesn't drop down below my warm up enrichment settings, which is 160. With a 160 thermostat it would drop to 155 in the winter... I have an aluminum radiator, with 2 1" tubes, and dual electric fans. I don't remember their diameter, they're mid 90's Dodge Intrepid fans. Most of the year low speed will keep it 185 or less. But high speed is set to come on at 194, and that will happen occasionally in the hottest part of the year. High speed takes it back to the mid 180's and then it cycles back to low. The ECU has made a difference by allowing timing settings that wouldn't be possible with a distributor, and the ability to control the fans optimally.
Old 07-25-2021, 07:37 AM
PunchT37's Avatar
Modern cars do run at 200 to 210. BUT, they don’t have carbs with low pressure fuel boiling problems. These carb’d engines need to be run cooler these days with pump piss.
The Following 4 Users Say Thank You to PunchT37 For This Useful Post:
Old 07-25-2021, 07:56 AM
roger1's Avatar
roger1 roger1 is offline
I think GTOJones proved that the Coldcase shroud isn't a good design. He's convinced me to go to a Coldcase and use a stock shroud and clutched fan.
I am also not a proponent of drilling holes in a thermostat. Even two 1/8" holes are going to make it slow to warm up in the winter and potentially never get up to temperature. I've done it in the past and that was my experience.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
Old 07-25-2021, 08:49 AM
389 389 is offline
455 Pontiac 160 Stant Super Stat with a 1/8" hold drilled into the base to let the air out when filling the radiator. I use a clutch fan with a top and bottom tank Champion all aluminum radiator. Never had any issues in 10+ years.. My engine stays between 160-180.. It has a 041 cam...
454 Chevrolet 160 Stant Super Stat 1/8" hole in the base, Champion side to side tank radiator. No shroud. Temps stay between 160 to 170 and never fluctuate rapidly. This motor is very stable and smooth. Being a Pontiac guy all these decades, I have to say, this Chevrolet big block is truly an amazingly well thought out engine...
Old 07-25-2021, 09:16 AM
Formulajones's Avatar
What my father said in post #8 is right on the money. The Cold Case radiator is an excellent piece, we've used a few of them now. The dual electric fan setup however we struggled with. I came to the conclusion the unit was too shallow and it blocked too much radiator to allow air flow through the unit while moving. Once his car heated up it would never cool back down. Stock clutch fan and shroud back on the car and now it just doesn't get hot at all, never over 175. For an engine of that size and the HP it makes, that says something about the quality of that radiator and how well the stock fan setup will work especially here in Arizona.
As far as running 210, on a classic car that's just too high for my comfort zone. Our cars for starters push the pump gas limitations for the compressions we run. So it's imperative engine temps are kept under control.
Also at carburated fuel pressures, and todays fuels, vapor lock can be a real issue so again, keeping engine temps under control is a big player in keeping that in check.
Because of all that, and since we daily drive them throughout the year in the AZ heat, and can't have those types of issues, I keep our cars running on the cooler side of things. Typically, all the cars here either run a Cold Case Radiator or a Griffin radiator, they all have 160 stats, stock type clutch fan setups and factory shrouds. This seems to keep all the cars running in the 170-175 range even in the peak of summer when temps are 110+, whether it's a SBC, a BBC, or a Pontiac engine.
https://youtu.be/XqEydRRRwqE
The Following 4 Users Say Thank You to Formulajones For This Useful Post:
Old 07-25-2021, 10:19 AM
Stuart's Avatar
Stuart Stuart is offline
Was the drive home on the highway, or on surface streets with stop lights and traffic? If it was the latter, the short distance combined with lower airflow at lower speed probably were why the temp didn't come down. I'll bet that if you were driving at a faster speed for more miles it would have dropped. Does the car have a/c? Of course that will make it run hotter too.
Old 07-25-2021, 10:24 AM
I am going to take it out again and see what it does, perhaps I didn’t drive it far enough for it to cool back down.
The 210 makes me a little nervous as well (reason for the post), I’m okay if it gets to 210 sitting in a drive through for 15-20 min, but I want it to come back down.
What you are saying about the electric fan shroud makes a lot of sense- I may try that.
Old 07-25-2021, 10:25 AM
The drive home was just stop light traffic and neighborhood streets. No AC on the car as of now
Old 07-25-2021, 10:34 AM
PunchT37's Avatar
What thermostat?
Old 07-25-2021, 10:43 AM
i82much's Avatar
i82much i82much is offline
i have an older rodney red alum radiator in my 65 with a 505, e-heads, and dual electric fans, i think rated at 2500 by flex a lite. with a 180 thermostat it stays under 200, cruise at 190 on the country roads.
mine are wired to thermostatic switches and also have a manual switch and indicator light for each. light is on if the fan is on. the manual switches are nice because i can turn the fans on whenever i am getting ready to shut the car off to cool it down a bit first.
only caveat is that i only drive at dusk after the kids go to sleep, and i left the carb a little rich. not sure if it would stay that cool in 95 degree weather or if i leaned out the carb. vacuum advance is a big deal for running cool too, mine seems to be about right.
but i don’t want to drive a dark car with dark vinyl seats on 95 degree days anymore, been there, done that, burnt the back of my legs!
Old 07-25-2021, 10:54 AM
Cruise on the highway at 65…..temp is around 202. Get off the hi-way and at a light…temp gets 195-198….under 200 on back roads. Still rocking the Original 4Core Harrison rad….was recored with a “Desert Cooler Core”…shroud …and Hayden HD clutch fan.. Car has original AC …and the original 7 blade ..19 inch fan . Did the flex plate in the water pump tweaking too
Old 07-25-2021, 11:23 AM
I believe the car has a 160 thermostat but it’s been so long I’m not really sure
It sounds like I am probably not going to hurt anything with the driving I do but there is still room for improvement.
