Old 02-18-2021, 06:30 PM
misterp266's Avatar
Default Stockton Wheel
Would like to get a set of 15” dog dish wheels that clear disc brakes for a ‘63 Catalina. Has anyone dealt with Stockton Wheel recently?
" Darksiders Rule "
Old 02-18-2021, 06:52 PM
tom s tom s is offline
Been many years,great work but not cheap.Tom
Old 02-18-2021, 09:27 PM
Stuart's Avatar
Stuart Stuart is offline
Anecdotal information, but I was reading a discussion on another board recently that indicated that recently they've been slow to turn around orders.
15" steel rims from a 1971-1976 full size Pontiac will fit your car and should be easy enough to find, although I don't know about being able to run period dog dish caps on them.
Old 02-18-2021, 09:55 PM
Friend of mine had 15in 8 lugs made a year or so ago and took awhile.Tom
Old 02-19-2021, 08:11 AM
The Champ's Avatar
I've run dog dish caps on my '64 GTO with the original 14" wheels, factory 15" wheels and now 17" bare steel wheels from Wheel Vintiques (through Summit).
Summit listing for 5x5 15" wheels - I think that's what you're looking for.
https://www.summitracing.com/search/...ques-62-series
I'm very happy with my 17's by WV.
Old 02-19-2021, 09:23 AM
Not answering the man's question Mr Champion.
As Stuart alludes to, early Pontiac poverty caps attach differently than '64 through mid 70's wheels, thus the need for Stockton Wheels services.
Old 02-19-2021, 09:54 AM
The Champ's Avatar
OPH
I wasn't aware of any structural difference between a 1963 wheel and a 1964 wheel.
I apologize for not knowing.
It's been nearly 50 years since I owned a pre '64 Pontiac (Bonneville), but that had full wheel covers, not dog dish caps.
Old 02-21-2021, 04:11 PM
misterp266's Avatar
Originally Posted by The Champ View Post
OPH
Full size cars had clips to hold the caps on up until 1964. 1965 and up they used caps like you have on your A body. I have not found anyone that’s not in California that does custom steel wheels. Shipping both ways would add a lot to the cost. Seems like with the lack of 14” tires, a 15” period correct wheel would be a good idea. I have a perfect set of caps and NOS clips, just need new wheels. . . .
Will probably run something else for a while.
" Darksiders Rule "
Old 03-02-2021, 06:22 PM
389 389 is offline
Check out Summit. Look up Wheel Vintiques Series 62 wheel in 15x7 with a 4.25 back space...
Old 03-02-2021, 08:06 PM
ZeGermanHam's Avatar
These are what I have on my car. Got 'em new from Summit a few years ago for $90/ea with free shipping. Looks like they are $104/ea now.
1998 BMW 328is (track rat)
Old 03-03-2021, 08:54 AM
The Champ's Avatar
That's what I posted up back on Feb 19th.
Evidently the Series 62, which I have on my '64 GTO, has a different center hub than what the early 60's big cars have - which won't allow the earlier poverty caps to work.
Old 03-03-2021, 03:22 PM
misterp266's Avatar
Correct.
I already have a set of WV Series 37 with plain caps which I guess is what I’ll be using.
" Darksiders Rule "
Old 04-26-2021, 10:33 AM
erliabol erliabol is offline
Have you found the dog dish wheels that you are looking for?
Old 04-26-2021, 11:35 AM
I have a set of dog dish Pontiac wheels on a set of 15x6 steelies that I kept after selling off a '78 Bonneville.
Ran them with disc brakes and no issues for several years on my '68. I wanted a wider wheel in back and ordered a pair of Wheel Vintiques and I never could get the original caps mounted on the aftermarket wheels. Wound up returning them and going with Torque Thrust mags. Still have the GM wheels and caps in my basement.
I know this has little to do with a '63 model, just saying, I had issues with OEM caps on aftermarket wheels but none at all fitting the caps on a 1978 B-body OEM wheel.
Old 05-06-2021, 04:35 PM
misterp266's Avatar
No.
But, while checking to see if the Wilwood calipers fit the Scarebird brackets, I found that the WV 37 wheels I have will not clear the Wilwood calipers. Wheels are 15x6.
Next step is to try some TTOs I have on my ‘66 Catalina to see if they clear. I believe they are 15x7.
You would think that a 15” WV wheel would work.
" Darksiders Rule "
Old 05-14-2021, 03:43 PM
misterp266's Avatar
TTOs clear fine. 15x7. Not what I want but they’ll due. For now.
Still want to run early dog dish caps . . . . .
" Darksiders Rule "
