Old 02-09-2010, 11:29 PM
Not trying to upstage anything here. This is a great thread and very informative...but for some that are looking for even more of this kind of info, HPP ran a great 3 part piece on rebuilding a Pontiac 455 a few years ago with plenty of specifics and great photos. All three are available for viewing online.
Here are the links-
Part I
Part II
Part III
Old 02-25-2010, 02:36 PM
Need For Speed's Avatar
Need For Speed Need For Speed is offline
Question
Originally Posted by Steve Barcak View Post
8. You did not add the important cooling holes in the deck
Can you elaborate on this, pics, how to, etc? I used the search feature and didn't find anything.
Anything I can do to keep the Poncho running cool, I'm down for it.
Thanks, Gary
Currently in the stable:
1966 C20 - D.D.
1968 Lemans - street/strip machine
1999 CBR1100XX - long distance steed
2002 TL1000R - canyon carver
2006 GTO - weekend toy
Live is good
  #63
Old 02-26-2010, 02:24 PM
Schurkey Schurkey is offline
Thanks, Gary
My thanks to Steve Barcak for previous photos posted elsewhere on this site; I used his cooling suggestions when I built the engine for my Father-In-Law's Firebird. Photo from FIL's engine:
From what I could see through the coolant passage holes in the heads I used, drilling the extra hole in the block deck and head casting was a waste of time. The cylinder head coolant passage where I drilled the hole was already getting water from other, nearby holes. Perhaps not all heads are cast like that, though.
  #64
Old 03-12-2010, 11:21 AM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
"The only things unaccounted for were the oil pump bolts, but after a quick trip to the hardware store we were back in business."
I did exactly the same thing with a fresh 1960, 389. Except I already had some grade 8 bolts on hand. It ended with distaster! About the 4th time I started the engine on a cool [40 degree] morning the oil presure went away completely. I pulled the pan to find the oil pump [melling] sitting in the bottom of the pan. The brittle grade 8 bolts had broken. I put it back together with good grade 5 bolts and never had any further problems.
Roll around in the excitement
  #65
Old 03-16-2010, 08:35 AM
grandprixaust grandprixaust is offline
great thread! finding information on these motors in Australia is incredibly hard. most people usually say " put a Chev in her instead" , which is something i myself would never do.
im curious with the rear main seal still though, is there any further information about avoiding the leaking ?
  #66
Old 03-16-2010, 07:07 PM
Red Coupe's Avatar
Red Coupe Red Coupe is offline
Pictures will be forthcoming along with description soon.
"Pay no attention to the planet Mopar. It is a strange and confusing place."
~Chiphead
  #67
Old 03-25-2010, 06:30 PM
Red Coupe's Avatar
Here’s a better description of several points that I made earlier in this thread on how to rebuild a Pontiac V-8. Some of you asked how to check thrust bearing clearance. Others wanted to know about the potential for rear main seal leaks due to machining errors.
This first picture shows how to check thrust bearing clearance using a feeler gauge. The concept is the same no matter how you do it; you need to rock the crank back and forth to make sure you have enough, but not too much, free play in the crank. Measure between the face of the bearing insert and the crank. In case of Pontiac V-8s, you are looking for .003 to .009 thrust bearing clearance. On Pontiac motors, the thrust bearing is installed in the #4 main bearing bore (not all V-8s are the same.)
Here's another way to check thrust bearing clearance. This method is a little more precise. What you need to do is set up a dial gauge that is zeroed out when the crank is pressed all the way towards the back of the block. When you pry (gently) the crank back and forth, you can directly read the clearance value off the dial gauge.
This picture shows the machine work around the rear main. You can see the groove where the rear main seal fits. In some cases, the factory didn't get the machine work perfectly concentric around the crank, and I’ll explain why this can cause a problem.
In this picture, you can see the use of a vernier caliper to measure the depth of the rear main seal groove on the driver’s side of the block. The next picture shows the same measurement on the passenger’s side of the block.
If the rear main seal groove was not concentric around the center line of the crank, the two readings will be different. Apparently when the factory installed the original asbestos style rear main seals back in the 60s and 70s this was not a problem. With the newer style seals, the ability to compensate for variations in machine work isn’t as good, and this problem can lead to a nasty leak. My machinist says he has only seen this error on 455 blocks. Nonetheless, once burned, twice shy, so he always checks when working on a Pontiac motor.
~Chiphead
  #68
Old 03-25-2010, 07:25 PM
Minor corrections/additions to a wonderful post:
The two readings could be identical and the seal "could" still not be concentric. This could happen if the seal groove is displaced too high or too low rather than too far to the left or right.
Better measure top 'n' bottom, too. You'd have four measurement points that better all be about the same.
It's not a matter of asbestos vs. modern seals. It's a matter of "Rope" seals which may or may not be asbestos vs. lip seals which can be neoprene, Viton, or some other "rubber" material. A lip seal has a very limited range of allowable misalignment with the shaft, AND they need a fairly smooth surface for the lip to ride against.
Of course, you aren't going to buy an asbestos seal any more; I think the modern rope seals are a fiberglass material. And they don't seem to work as well as the genuine asbestos material--but--the EPA and OSHA frown on asbestos. Even so, if you have a block/cap that has the seal groove not concentric with the crank centerline--rope seals are your best friend.
I don't like rope seals except for agricultural or industrial use where the seal has to deal with abrasives--such as a pump used on "contaminated" liquids. (So I avoid using them on automotive engines where there shouldn't be any abrasive in the oil) Sometimes there's no choice, though--either the seal groove isn't concentric (some Pontiacs and perhaps others) or the crankshaft isn't smooth enough for a lip seal to rub against and live.
  #69
Old 03-25-2010, 08:16 PM
Grand73Am Grand73Am is offline
The Graph-tite seal seems to be the one to use based on what I've read here in the past.
  #70
Old 03-25-2010, 10:45 PM
Red Coupe's Avatar
Excellent points Schurkey, thank you for improving this thread!
~Chiphead
  #71
Old 04-02-2010, 11:37 AM
great photos and info! thanks !
if the crank was freshly machined would that mean it would have a smoother surface for the lip seal ?
  #72
Old 04-02-2010, 06:25 PM
No. No crank grinder I know has a thin enough grinding wheel to do the sealing surface.
Some cranks are deliberately stamped with a pattern of "hash marks" that looks like
all around the sealing surface; that helps the rope seal do it's job; but it's not good for lip seals. I polish the hash marks (if they exist) with emery cloth to smooth them some. You'll never polish them completely away. Other times, the rubber lip wears a groove in the crankshaft just like the front seal can wear a groove in the hub of the damper. Then you either need a special seal that has a re-positioned lip; or you're back to packing rope.
  #73
Old 04-25-2010, 09:50 AM
tjdjr's Avatar
tjdjr tjdjr is offline
When you broke in the cam did you only use a single valve spring ?
  #74
Old 11-04-2012, 02:38 PM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Originally Posted by goatman65 View Post
Jim Hand's how to build a Pontiac book has a lot of useful info, but it really isn't a step-by-step detailing of rebuilding an engine. So, I think there is still a need for such a book, as evidenced by the response of Pontiac hobbyists on this thread. I hope this encourages one of the Pontiac engine experts to publish one.
Yep.
You need Rocky Rotella's book. Came out in 2011, I think. I just picked up a copy from Amazon.
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
  #75
Old 11-04-2012, 03:34 PM
Thanks, that's a good reminder, but this thread is 2-1/2 years old. So, we all pretty much know about Rocky's book by now . I got mine right after it became available. And it's great!
Steve F.
  #76
Old 11-05-2012, 03:22 PM
OINK 1's Avatar
OINK 1 OINK 1 is offline
Default Jeses !
Port the heads !!
Greg Merrick
  #77
Old 11-06-2012, 05:56 AM
Nicks67GTO Nicks67GTO is offline
subbd for future refrence
Nice post!
  #78
Old 11-06-2012, 11:25 AM
HWYSTR455's Avatar
Using any type of sealant or surface prep on head gaskets depends entirely on the type of gasket used. Most go dry these days, FYI.
Ring Gaps - Follow the ring manufacturer's recommendations, and check for any notes that came with the pistons.
Most rod bearings for Pontiacs are now chamfered on both sides.
Here's the one thread I recall, Chiphead made a good post:
http://forums.maxperformanceinc.com/...+assembly+tips
Now I exclusively use assembly lube during assembly. Not sure if I commented on cleaning cyl walls with WD-40 or not. Trans fluid works too. Floating pins get oil. Gasket surfaces get wiped with thinner or acetone prior to assembly. I do the same for block and rods prior to inserting bearings. Use lint-free rags. Anti-seize on timing cover studs.
