Old 09-06-2004, 10:36 AM
6D6GOAT's Avatar
6D6GOAT 6D6GOAT is offline
does anyone know what the line pressure (to the trans cooler) is for a TH350?
thanks.
Vic in SoCal. Follow me on Instagram- Cloud9orbust
66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi.
My T56 Install
My Turbo Build
My Vortech Supercharger Build
Hyd Throw out bearing
Misc Build Pics
May the Karma Gods meet you half way....
6D6GOAT's Avatar
thanks.
My T56 Install
My Turbo Build
Misc Build Pics
Old 09-06-2004, 10:42 AM
79GP6.6L 79GP6.6L is offline
The dyno sheet for my TCI TH350 lists cooler pressure as 1 gpm & 25 psi at 2000 rpm in high gear.
Old 09-07-2004, 08:29 AM
PROBRD PROBRD is offline
Here is the normal specs for a th350:
Nuetral 1000 rpm 55 to 75 psi
Low or D2 1000 rpm 85 to 110 psi
Drive 1000 rpm 60 to 90 psi
Reverse 1000 rpm 85 to 150 psi
1/8th mile 6.52 @ 104
1/4 mile 10.43 @ 128
Old 09-07-2004, 07:37 PM
Malky Malky is offline
PROBRD, I think those are the pump output pressures. The supply to the external cooler comes off the "dump" port of the pressure regulator and is a lot lower pressure.
