Old 06-28-2004, 04:35 PM
67cruiser 67cruiser is offline
I just got the whole gto package back together and still have the problem i had a few yrs back!! everytime i conect the battery its giving off a spark enough to scare you or make you junp!! it almost sounds like a short somewhere?? but where do i begin?? anybody please??? Bran new engine harness, tail lite harness, front headlite harness
is also bran new!! open for suggestions.
Old 06-28-2004, 06:43 PM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
You have a major short or power drain somewhere. Does the car have A/C?
Old 06-28-2004, 06:55 PM
george kujanski's Avatar
You should measure the current draw when you connect the battery to see if indeed it is high enuf to be called a battery drain or a short. Sometimes it may spark when you connect, but the current draw may be temporary or not high enuf to be a problem.
Get a multimeter, start on the 10ADC scale, and with one of the cables off, connect one side of the meter to the battery, the other to the cable. If the value is low enuf, change the meter to the mA scale, (usually 200 or 300 mA), and measure again. Normal will be about 10 to 20 mA or less.
George
Old 06-28-2004, 07:56 PM
no ac just power sterring and brakes thats it!!
Old 06-29-2004, 05:44 AM
jeffsgto jeffsgto is offline
I agree with George, test it. Sometimes electronic/digital radios, etc. will draw a small amount of juice when the battery terminals are first connected for the memories in the radios. Also, make sure doors are closed so that door light switchs are not activated. Like George indicates if you are drawing enough amps to cause a concern, an easy start is to unplug the firewall bulkhead connections. This will narrow the search to either the engine compartment or inside the car. If its in the car, start pulling fuses until you find the faulty circuit.
Jeff
