Old 02-26-2004, 12:22 PM
69GTODUDE3E 69GTODUDE3E is offline
I am currently removing the body bolts from my 69 GTO to lift the body off of the frame. The problem is, I broke a couple of the bolts. Is this a big problem?? I sure hope it isn't.
http://www.cardomain.com/member_page...=358363&page=1
Great Fishing, No Snow...Ever, 80 Degrees and Poncho's Everywhere....I must have died and gone to Heaven!!!! Oh wait, that's right I'm in FL now!!
Old 02-26-2004, 12:47 PM
David Jones's Avatar
What bolts broke? Can you weld? Is it the bolts that broke or the weld nuts on the frame? Prepare to learn some new skills.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
Old 02-26-2004, 12:55 PM
Both....I broke the one on the drivers side rear and the nut broke loose on the pass. side rear. Yes I can weld, but how do you get to the top of the bolt/welded nut. Its somewhere between the trunk pan and the frame. Would I have to cut my trunk up??
Old 02-26-2004, 01:04 PM
goatseeker's Avatar
goatseeker goatseeker is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Would I have to cut my trunk up??
<HR></BLOCKQUOTE>
Yes
I know of no other way to access the caged nuts other than to cut a hole from the inside and remove it. Then weld a patch back over it.
As David said, prepare to learn some new skills....and cuss words
http://kurtspontiac.homestead.com/TimSimpson66GTO.html
Old 02-26-2004, 01:09 PM
New Cuss Words!!! WoooHooo!!! And I thought I knew em all. Well, I really didn't want to hear that, but if that's whats gotta happen, I guess that's what I'll have to do. Are all of them that bad to get to?? I have only messed up the 2 rear ones. I didn't want to really screw myself so I quit while I was a bit behind.
Old 02-26-2004, 01:17 PM
Supertacks Supertacks is offline
Here is a little trick I learned from another post on these boards
When you cut your access holes in the trunk pan, only cut three sides. Peel back the metal, and remove the bolts. After you have completed your repairs and you are ready to put the body back on the frame all you have to do is bend the little flap back down and weld the three sides. It will fit perfectly and you won't lose the piece you cut out if you remove it all the way.
Old 02-26-2004, 01:19 PM
Great Idea Dude!!! Thanks for the help!!!!!!! You guys rule.
Old 02-26-2004, 02:37 PM
Are you using lots of penetrant and letting it soak?
Old 02-26-2004, 02:39 PM
Yes I have soaked the hell outta them with Kroil, but it's not working very well. In the past Kroil has worked on everything. Maybe I'm just stronger now.
Old 02-27-2004, 12:10 PM
Judas Judas is offline
Great idea Supertacks!
"On the highways, it was a white-line nightmare...men were battered and smashed..."
"If you can’t fly then run, if you can’t run then walk, if you can’t walk then crawl, but whatever you do you have to keep moving forward."
