Old 12-31-2003, 05:49 AM
bluesman bluesman is offline
As I decompressed the piston in the caliper on my wifes 2000 Impala, this happened. Is there reason for concern? I only replaced the pads and reused the rotors. Just don't want her to have any surprizes down the road. (Been there already one time)
Chas.
Chas.
Chas.
Chas.
Old 12-31-2003, 07:58 AM
Dave A Dave A is offline
No reason for concern. When you are done with the brake job, adjust the fluid level until it is at the 'max fill' line. It sounds like brake fluid must have been added at some point (to the resevoir), so that when you return the caliper pistons back to the 'new brake pad' condition, you had too much fluid in the system and it overflowed some. You'll of course want to clean up where the brake fluid spilled, or it will eat up the paint.
Old 12-31-2003, 09:10 AM
Dave,
Thanks! From the looks of your location, you'll be watching the game tonight too I assume. Though I am much closer to the Michigan State territory, I still say...."GO BLUE!!!!
Chas.
Chas.
Old 01-01-2004, 08:06 AM
Yes, Go Blue!!!! I'll be watching at 5:00 today.
Old 01-01-2004, 11:30 AM
78 GHOST 78 GHOST is offline
Trivia: How do you know if the pads/shoes are worn out without looking at the wheels? Yup, if the fluid level is low.
____________________________________
Much love out to my Peeps
"I work in high speed aluminum tubing."
Old 01-02-2004, 10:38 AM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Trivia: How do you know if the pads/shoes are worn out without looking at the wheels? Yup, if the fluid level is low.
<HR></BLOCKQUOTE>
All the shops around here have a disclaimer plastered all over the shop that says during an L.O.F., they will top off all fluids except brake fluid for that reason, and in case you actually have a leak.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
The point to life isn't necessarilly the decimal.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 01-02-2004, 01:06 PM
Larry Navarro's Avatar
another sign of low fluid level is the slowly leaking wheel cylinders at the rear drums.
i have experienced this a couple of times on late model gm trucks with high mileage.
no signs of a brake problem until the fluid is abnormally low.
1973 SD455 T/A
1979 SE474 T/A
http://community.webshots.com/album/16587603rOyvmFCiHs
