Old 01-04-2005, 05:41 PM
charlie66's Avatar
They also make a TKO500 and a TKO600 the 500-600 symbolize how much tork they can handle.
My Half AN Injun.....
charlie66's Avatar
Old 01-04-2005, 06:44 PM
Formula8's Avatar
Formula8 Formula8 is offline
I don't recall the question but the primary difference is in the first gear ratio which in turn affects the torque capacity. TKO 500 uses a 3.28 first gear while the TKO 600 uses a 2.89. The TKO 600 has closer ratios as well. No brainer choice here since they both are very close in price.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 01-04-2005, 07:56 PM
charlie66's Avatar
I'm new to this site,I'm learning how to use it.The TKO600 reply was ment for a question from a different post,Sorry.
Old 01-04-2005, 08:03 PM
charlie66's Avatar
Senior chief,I'm wondering how the TKO500 is holding up against your 455's power.
Old 01-04-2005, 08:41 PM
Formula8's Avatar
Welcome aboard Charlie,
I have a TKO600 and my 455 is currently being built. Considering I have a street car set up for handling with 17" wheels and a 3.73 gear, I don't think I'll ever get enough traction to break anything.
That being said, the TKO 600 is the only manual trans with OD that easily bolts into our cars. So there really is only one choice if you need 600 ft/lb of torque capacity.
Old 01-04-2005, 09:28 PM
charlie66's Avatar
Senior chief,I own a 64 GTO.I was told in order to install a TKO in in it, I would have to cut the floor out in the hump area.Do you know if this is true.Also what do you think of the Jerico 5 speed?
Old 01-04-2005, 11:14 PM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
The Jerico's are great but I doubt you will find one close to the same price as a TKO.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 01-05-2005, 04:59 AM
Formula8's Avatar
My application is a F body where the tunnel does not need to be cut. It's my understanding you have to do more cutting with an A-body car like yours. Go to the search function and put in "TKO". Or you can follow this link to more info: http://www.classicchevy5speed.com/64...tall_notes.htm
Old 01-05-2005, 11:56 AM
charlie66's Avatar
Like i said before i'm new at this site,My friend was making fun of me earlier because i call you senior chief,He said that's not your name it's your rank (what do i know)So i guess your name is formula8.Any way thanks for the info i'll check it out.
Old 01-05-2005, 12:01 PM
charlie66's Avatar
Does any one know what the Jerico 5 speed can handle in terms of torque.
Old 01-05-2005, 12:24 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Welcome aboard Charlie! Jerico's are the best but are VERY expensive. The TKO is a good trans, quite a few people are running them. Only problem is missing shifts at the strip, maybe someone that has one would comment on strip performance. For a look at Jerico's, Click Here. Goodluck-Jim
Old 01-05-2005, 12:48 PM
charlie66's Avatar
Jim,Thanks glad to be aboard. Would you by any chance know how much power they can handle.The Jerico that is. Thank, Charlie.
Old 01-05-2005, 01:20 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I think the Jerico can probably handle anything you can throw at it. Alot of the stockers/super stockers use them.
The old Doug Nash/Richmond RACING 5 speed can handle alot of torque also.
Skip Fix
Old 01-05-2005, 01:42 PM
gearbanger's Avatar
gearbanger gearbanger is offline
What about these missed shifts at the strip? I am about ready to order one, but I need to find out about this! Jon Burchmore should be able to tell us. He is an avid drag racer and has a tko600 in his car now.
Old 01-05-2005, 03:29 PM
charlie66's Avatar
I also would like to find out about those missed shifts,When you find out please post it.Thanks
Old 01-05-2005, 03:43 PM
Junkyard Dog's Avatar
SInce this is in the street section, you should be aware that the Jerico will WHINE really loudly while dirving around due to the angle of the teeth. No such issues with the TKO.
Badder than old King Kong
-Jim Croce
Old 01-05-2005, 06:01 PM
charlie66's Avatar
Jerico has a new 4 speed,The WC4-4 have you herd about it?It has straight cut and wider CNC Machined from VAR (Vacuum Arc remelt)steel gears.Also they say it has a proven 6 lug Dog ring and slider shifting system that will provide clean butter smooth positive shifts.What's a 6 lug dog ring does any one know?Is it like a sincrow? Thank's
Old 01-05-2005, 08:35 PM
DiamondJim's Avatar
Charlie, Jericos are run in Pro-Stock, they list 1200hp, 6 sec Pro-Stocks are putting out more. As far as missed shifts I have no actual experience, just repeating what I have heard, I think it is on the 2-3 shift, due to a narrow gate? I sure hope someone that races one chimes in here, please do not base a decision on what I said, I could be wrong. -Jim
Old 01-05-2005, 11:55 PM
ChrisTransAm78's Avatar
ChrisTransAm78 ChrisTransAm78 is offline
I have a TKO 5 in mine. Kinda noisy but then I don't have anything as far as carpet and sound deadner yet... Shifts smooth (hda to break it in) Got it Forte's..tell him I sent ya! Got pics of the install for a 78 TA...not sure what yours is...
18rs and good luck!
http://www.christransam78.com/
