Old 12-09-2003, 10:55 PM
68andTopless 68andTopless is offline
I am switching my standard door panels for deluxe in a 68 FB. I recently picked up the deluxe regulators and door handle hardware. How do I swap them? Is this a two person job since the window needs to be supported during the swap of the regulators? How does the door handle mechanism on the deluxe work since it doesn't clip on (similar to a window crank) like the standard door handle does? I'd appreciate some advice since the books don't offer much help.
Old 12-10-2003, 02:50 PM
einstein's Avatar
einstein einstein is offline
It's really quite simple to do, but complex to explain. When you get the doors apart, you'll see just how simple it is.
I've done many window regs without help. Don't take apart anything related to the window guides. Just remove the regulator itself with the window mostly down so it doesn't drop hard into the door.
The door handle screws onto the pull mechanism with two phillips screws.
Glenn Uettwiller http://home.earthlink.net/~birdman8/index.html
In religion and politics, people's beliefs and convictions are in almost every case gotten at second hand, and without examination. -- Mark Twain
Old 12-10-2003, 04:07 PM
ponjohn's Avatar
ponjohn ponjohn is offline
The regulators are actually different from std to delux? How about on a 67?
John
67 Firebird
"Dogs are not our whole life, but they make our lives whole." -Roger Caras
Old 12-10-2003, 04:40 PM
einstein's Avatar
The 68 and 69 custom door trim panels are thickly padded. Same for Camaro. That requires a longer shaft to keep from the crank handle chewing up the panel. I believe it's just the door units, though. The rear quarter panels are not any thicker than standard.
Old 12-10-2003, 10:42 PM
Thanks Glenn,
You would think it would be easy for them to make an extension to the window crank so that you didn't have to change regulators at all. Does the window need to be adjusted once the switch is made?
Old 12-29-2003, 06:59 AM
ponjohn's Avatar
Bringing this to the top AND wanted to know if upgrading a 67 to delux requires new regulators?
Any pics of 67 delux interior? Mine is standard interior and I am also changing the color so may as well do it all at once.
Thanks-
John
67 Firebird
Old 12-30-2003, 09:15 PM
einstein's Avatar
I don't think the 67 had a different length regulator shaft.
Extensions? Won't work. There's no way to attach such a device.
Regulator replacement does not require removing or adjusting the glass, as the glass runs in two vertical tracks. A horizontal track affixed to the lower part of the glass is the only connection of regulator and glass, and can be removed with the glass still in the verticals.
Marriage resembles a pair of shears, so joined that they cannot be separated; often moving in opposite directions, yet always punishing any one who comes between them. -- Sydney Smith
