Old 05-31-2004, 01:52 PM
DISCO_STU29 DISCO_STU29 is offline
Hey
I have just bought a 1971 350ci Oldsmobile for my 1978 T/A, it is completely stock besides the Hedmen headers, its is rated to 260bhp am told but the engine needs a new carb. I would like to know what would be a good carb to go for? The car is intended use as a daily driver with the odd trip down the strip, and I love to rip away from the lights when racing the British and Japinesse cars down the street.(Scotland, UK)
I have a brand new Holley 750cfm Vac Sec that i was going to use on the original Pontiac 400 motor before the piston rings went. I also have the original Q-jet from it, would either of these carbs be any use or are they to big? Or should i go for a 600cfm Edelbrock?
I've always fancied a Double Pumper but are they really worth the extra petrol? I am intending to use an 1" spacer if that makes any difference?
On a different subject does anyone know what the intail timing on the 1971 350ci Olds is?
And
Will Pontiac 400 headers fit on to a 350 olds or will there be some modification required?
Thanks for any help
Cheers
Stu
Hey
And
Thanks for any help
Cheers
Stu
Old 06-01-2004, 02:10 AM
kate`s67gto's Avatar
kate`s67gto kate`s67gto is offline
I own a 1970 Olds with a 350. The timing on it is 10* btdc. For your carb the pontiac should work. As far as the hedders i doubt they will work without modifications. Is this engine gold or orange ? I ask this because mine is a gold engine a true olds engine.
Scott
If you always do what you always did
You always get what you always got
Old 06-01-2004, 06:03 AM
63 Pontiac's Avatar
63 Pontiac 63 Pontiac is offline
This Olds website has good tech support: http://www.realoldspower.com/
1963 Catalina 2 door hardtop
1968 Catalina 2 door sedan
Old 06-01-2004, 09:49 AM
Its a gold one, does this make any difference? Does the Holley Vac Sec work differently than the Q-Jet? Do you think the holley it would pump into much fuel.
Old 06-01-2004, 11:57 AM
Okay so it is a true olds engine. If you want the correct carb for that engune it is 7041250
or 17041250. The holley could be a bit large in size for that engine. The holley vacum secondaries should work the same as a quadrajet, not exactly sure though.
Scott
Old 06-03-2004, 02:59 PM
Hey guys now for my next problem,
Ive have just picked my my new motor and its a 1971 350ci Olds, 45Kmiles, gold in colour, completely stock, Points dizzy, a two barrel Intake manifold and a 2 barrel Rochester carb.
I also have a 1979 403ci Olds stock motor, and i what to put the HEI dizzy from the 403 into 350 is this possible?
I would also like to know if i should put the 4 barrel intake from the 403 onto 350 or would this be restrictive on horsepower and torque or should i go for an edelbrock performer? Did my engine of that year ever come with a 4 barrel intake that i can search for?
Cheers
Stu
