does anyone still race a 4-speed,if so what kind
the most popular for high HP use is the Jerico.
I'm going to be using a M22 Supercase Muncie.
http://www.5speeds.com/case.html
_________________________ _________________________________ http://www.youtube.com/watch?v=_qZgOpn-w-o <<< Burnout Video ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Treat Me Good, I'll Treat You Better; Treat Me Bad, I'll Treat You Worse" Sonny Barger ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
I race a clutch assisted Jerico DR4 with road race sliders and the standard H pattern Hurst shifter, Super duty 1350 yoke and 1350 series U joints with solid cross.
Ram adjustable long style clutch.
Reliving my old man's glory days: street racing his '62 Savoy 413 wedge Eastbound on Dempster Rd.....any takers? |
Occassional strip duty, BW-T10 screaming for mercy.
![]() Power shifting!....pedal to the floor, fannin' the clutch, engine singing off the rev chip. Its a blast!!!!
Home of WFO Hyperformance Shaker induction. |
Well I run the least desirable of all four speeds, a Saginaw but have had good success with them. I'm also using a Centerforce single disc clutch. Launch around 4 grand and shift at 5600.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
I,ve got a Liberty slick shifted Hemi NP 833 4 speed that was in my Mopar bracket racer, Thinking about droping it into my 73 SD T/A just for fun. It held up to a 590fpt 440 in a 70 Cuda , think it will work behind my pontiac. Jeff
1973 Super Duty Trans Am 455SD, Auto,White/White, Best Et: 11.39 @118 on Drag Radials 3875# |
Muncie M-22.Hint-Redline MT90 is GREAT stuff for manual trans shifts. -JimT
Im using a Liberty modified (to fit a GM) 'Hemi' A833 4 speed in my street GTO (70). Very soon (next month) Im going to switch to the new TKO 600 5 speed and the 4 speed will be for sale.
Tom, I have a question about your 833, is it a alum. case? if so have any problems with countershaft case hole elongation? or have they been bushed ? As you have probley guessed mine is a alum case based on the old Direct Connection part. And it does have case wear that needs to be adderesed, bushed once before. any help or suggestions? Thanks Jeff.
Jeff, I worked with a guy named Paul at liberty when I ordered the 4 speed. For strength reasons he recommended the iron case and standard 2.65 first gear, so thats what I went with. I have only put about 5 total hours of running time on the trans so far (most of it with the rearend on jackstands) so I have yet to hit it hard.
Tom, thanks , I do have a iron case to , it just weights a ton. I,ll have to get in touch with Liberty I guess,BTW I have had zero problems with this trans I don,t think it,ll ever break unlike those damm Muncies.
how much work has to done to put a hemi 4 speed in a f-body. would a cast case t-10 be as strong.
There are 2 major mods done to the 833 4 speed to get them to work in a GM application. The input shaft is custom cut to the correct length with the correct pilot bearing on the end. So you will need to use a 1 3/16" X 18 11" clutch disc. The other mod is a custom front bearing retainer that will fit correctly into a GM bellhousing and use a GM throwout bearing. You will need to re-drill 3 holes for the transmission mounting bolts and add a small tab made from .250" plate for the fourth mounting bolt (looking at the trans mounting surface its the bolt in the lower right). The trans mount is higher than a Muncie, so you need a spacer. This spacer doubles as an adapter so you can use a GM trans mount. The speedo drive is the same as a GM. You will need a 30 spline trans yoke put on your driveshaft.
Nothing to it. |
Tom interesting, mine uses a stock retainer with a hydraulic throwout bering. Must use a aftermarket belhousing (McLeoud Chev type) they have a removable ring in the hole that the retainer goes in. I do not belive the T10 would be as strong as the Hemi 833 especially after Liberty gears & sliders are used. Jeff
Seems like the new Tremec 600 is a better choice. It handles 600 ft lbs of torque and has a .62 overdrive to make your 3.90 gears seem like a 2.41 on the Interstate.
Badder than old King Kong And meaner than a junkyard dog -Jim Croce |
Super T-10 with the cast iron case is the ONLY way to go. I went through 2 super T-10's and rebuily one and split the case's on all 3. Have a 455 that would to the 1/4 in 13.00@107 spinning through 1st. About 480 HP. Got the iron case and no more problems.
------------------------------ Bottle or boost....help me decide!! |
Doug Nash 4+1 Pro shift with straight cut SAE 9310 steel alloy gears and 3.25:1 first
Working on going faster (and now staying dry at the same time !!) |
