Old 01-11-2004, 05:56 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
I have a 3 speed manual transmission out of a '67 LeMans Sprint and I need to identify it.Is this the only 3 speed manual trans. that came out in 1967?It has a large C-4 cast on the outer caseing.I was told there were Dearborn and Saginaw transmission made that year.Thanks Tim
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
1-GTO's Avatar
Old 01-11-2004, 06:04 PM
400 4spd.'s Avatar
If it has a sheetmetal plate on top it is the Dearborn toploader, fully synchronized and made by Ford.
Old 01-11-2004, 07:17 PM
400 4spd.'s Avatar
And yes, a Saginaw was available. The Dearborn was the "heavy duty" option, from what I've read.
Old 01-12-2004, 12:51 PM
Rugratman's Avatar
Rugratman Rugratman is offline
I thought the ford 3 speed was only used with a HO option. Maybe it was ordered special for the 326 ?!
Hang on to it, if it is the ford 3 speed.
........I'm just learning as I go.......
Old 01-12-2004, 03:24 PM
george kujanski's Avatar
The manual shows the Dearborn as the heavy duty option and it is obviously the Ford toploader. The Saginaw is the other 3 speed available, standard design. I had a '67 Sprint and it had the Saginaw.
George
Old 01-12-2004, 04:43 PM
1-GTO's Avatar
OK guys..I found out for sure its not the heavy duty Dearborn 3 speed trans!My Restoration Guide states that they made 3 speed Muncie transmission also?
I will try to find some more codes on the tranny as I clean it up.So far here are the date codes and part numbers I found.
GM 6
Part # 3858988 or its 3858986 (the last number is hard to read).date code of C216 on the housing.
Part #3873886 on the tail shaft with date code of C236
Thanks for your help so far.
Old 01-13-2004, 06:22 AM
stevek0629 stevek0629 is offline
3-Speed trans ID
The Hurst catalog has a nice section on transmission identification. If you go to:
http://www.mrgasket.com/hurstmain.html
and select the Hurst transmission ID chart link you will get an excellent pictoral and text description of various autos, 4-speeds, and 3-speed transmissions.
This allowed me to identify my 67 Lemans 3-speed as the Ford version
Good luck!
Steve
Old 01-13-2004, 05:51 PM
1-GTO's Avatar
Thanks Steve....I went to the Hurst Site,but could not pull up any links to identify different transmissions!I have Web TV and it's limited to what can be pulled up so thats probably why I can find the link your talking about?So far I know its not a Dearborn trans.,just not sure if it is a Saginaw or a Muncie.
Old 01-14-2004, 07:33 AM
cammerjeff cammerjeff is offline
As far as I have been able to find out & all of the sprint manuals I have parted out over the years (approx 12 or so) They all came with saginaw's eather the 3-speed or the 4-speed styles.
The only exeption to this is the 69 4-speed Lemans & Tempest's that came with an M-20 Muncie and I have only seen 2 of these. The 69 Sprint Firebird's 4-speed's still had the saginaw.
So if it is the original trans, and it has a cast irom case, 99% chance it is a saginaw. But I have learned to never say never over the years.
Hope this helps, there is not very much info on sprints out there. I had to prove the muncie in my 69 tempest was stock years ago to a very unreceptive GTOAA judge back in the 80's
Old 01-16-2004, 06:29 AM
HURST LINK
1-GTO,
From the link I posted select "on line catalogs" and select the Hurst link. That will allow you to get either catalog sections or the entire PDF catalog.
The section you want is 5 fron the top, "Hurst Transmission ID Chart"
-Steve
Old 01-17-2004, 06:38 AM
Shadowjack Shadowjack is offline
Dearborns were put behind V8s with floor shifts. Not needed in OHC6s or column shifts.
Old 01-22-2004, 01:31 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Hurst made aftermarket linkage kits(rod & levers) for all of the transmissions that the Pontiac A-body cars used.
Peter Serio
Owner, Precision Pontiac
Peter Serio
Old 01-22-2004, 01:32 PM
More Hurst info:
Peter Serio
Peter Serio
