Old 12-08-2003, 01:16 PM
QWERTTROY QWERTTROY is offline
Has anyone ever tried carb spacers on a factory tripower setup? Would there be any hp gain from this?
Old 12-08-2003, 01:27 PM
Tom Vaught's Avatar
Boost Engineer
I have run offy aluminum spacers (1/2") on top of
the cast iron 66 intake to adapt Holleys. Most
feel that a "riser" will even out the flow after
the throttle blade and will keep the fuel-air
mixture from hitting the floor at high velocities
but historically Pontiac tri-power intakes do not suffer from that problem as they were well designed by the factory for their carbs.
Tom V.
Old 12-08-2003, 02:36 PM
Rugratman's Avatar
Rugratman Rugratman is offline
Just curious, but what about the fit ?
What Holley's did you use to make them fit ?
I did not know that Holley made a carb that would fit on the stock intake ? Only on the spacers ? Any modifications ?
I'm thinking ahead for the new aluminum intake.....
........I'm just learning as I go.......
Old 12-08-2003, 03:08 PM
Tom Vaught's Avatar
Boost Engineer
I used a 440 six pack set of carbs.
I used Offy Holley to Rochester (Large base) spacers.
There were no clearance issues on a 1966 Tri-power
intake.
Tom V.
Old 12-08-2003, 05:36 PM
wheelspin's Avatar
Tom,
If this combo was tested, what performance benefits did you gain utilizing Holleys on the OE trip manifold ?
Les
66 GTO Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
