Old 12-29-2003, 01:44 PM
EricL EricL is offline
i have a 80 TA with a 455 and i put a electric choke on it. where is a good place to get 12 volts from? with the original choke wire on it dosn't put out enough to pull the choke off.
______________________________
1980 Special Edition Trans Am
1975 2 bolt 455, 6X-8 heads, summit 2802 cam, stock intake, edelbrock 600cfm.
TH350 trans and converter out of a 78 TA, 10 bolt posi rear with 3.42 gears, 225/70-15 tires.
Old 12-29-2003, 01:50 PM
BOWE62 BOWE62 is offline
+ side of the coil...
Greg Bower
Greg Bower
Old 12-29-2003, 05:43 PM
Should be a recessed male spade terminal in your factory fuse block, it's marked "accesory". Use it, but be sure & use a fuse or fusible link of sufficient amperage to protect the circuit.
This circuit should be an ignition hot circuit, which means it's hot when the ignition is on.
Old 12-29-2003, 09:16 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Easiest and most convienent is to go to the wiper motor. There is a lead that is energized anytime the key is "on"......Cliff
Old 12-29-2003, 09:54 PM
Bill Meyer's Avatar
Bill Meyer Bill Meyer is offline
Location: West St Paul MN/Mesa,AZ- depending on weather
I have found the cigarette lighter to be a good place to get a heavy duty/already fused wire from. (unless you still use it & that's another topic!!)-- Bill --Be careful though, as this ones always "HOT".
GT37 3600lbs...as featured on the cover of Pontiac Enthusiast Jan/Feb 2002 DOT/mufflers-all motor
6.49 @ 108
10.14 @ 133
GT37 3625lbs..Fastest bench seat, column shift, all steel,no power adders car at Norwalk
1.35 w/29.5x10.5x15
6.42 @ 109
10.09 @ 133
Old 12-29-2003, 10:43 PM
You need a feed that is ONLY LIVE WHEN the IGNITION is ON. Not live when accessory is on or battery voltage is live. You dont want the choke to be live when you are sitting there with the ignition key turned to accessory and listening to the radio. Also if you use battery voltage the choke will never close and will run down the battery with the key off.
Old 12-30-2003, 05:00 PM
tiacguy's Avatar
tiacguy tiacguy is offline
The factory uses the keyed hot wire going to the alternator. It should be the F wire on external regulator years and the (heavier) red (hot wire with key on) I think termanal #1 on the internal years.
Old 12-30-2003, 05:08 PM
firechicken's Avatar
firechicken firechicken is offline
What tiacguy said. Keyed hotwire from alt is the correct place for electric choke
