Old 07-03-2004, 11:19 AM
pontiacjim pontiacjim is offline
Has anyone tried putting the 2.11-1.77 valves
and screw in studs in # 15's. I've tried to find so # 64 but had no luck.
Jim
Jim
Old 07-03-2004, 03:10 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Jim, doing that to the #15's would make them very similar to the #64. Make sure to run run a 75-degree bowl hog after upsizing the valves. It will unshroud the entire area allowing you to take full advantage of the larger valve diameter
Old 07-03-2004, 03:31 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
A friend upgraded some and did a pocket clean up and they flowed with a regular big valve D port. Seems like that would make a good street 400 head. All of the exhaust holes are not drilled and some of the accessory bolt holes are missing for late model brackets.
Skip Fix
