Old 10-24-2004, 01:41 PM
twister11k twister11k is offline
I am looking at buying a 70 Trans am and have been researching it a little and have some unanswered questions.
- green interior on a t/a with white body, is this common?
- it is advertised as an automatic car with 3.90 posi gears in it, was that an option?
- the first numbers in the vin tag says it is a trans am but on the body tag it says it is a regular firebird, the car is from the NOR plant. I have heard that the cars that came from this plant had all the body tags saying that they were firebirds, no matter what. Has anyone else come across this?
Any help would be appreciated.
Old 10-24-2004, 06:39 PM
bonneville Joe's Avatar
bonneville Joe bonneville Joe is offline
From what I know, all T/As in '70 had blue or black interiors.
_____________________________
www.classicpontiacrescue.com
Old 10-24-2004, 07:14 PM
racerboy's Avatar
racerboy racerboy is offline
FWIW - My 1970 Trans Am came out of the Norwood plant with a T/A tag.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
Old 10-24-2004, 08:38 PM
transam_kahuna's Avatar
transam_kahuna transam_kahuna is offline
My Van Nuys 70 TA has red interior and my friends Van nuys lucerne blue car has sandalwood interior...a phs verified 70 with green interior would be interesting to say the least.
1978 TA
ram air V heads waiting to be run
2000 MT-500 Harley Davidson military motorcycle 1 of apx 169
1991 USMC KLR-250 "devil dogs" X's 2
1979 M-151 US Army Hooah!
1975 A-350 Condor Swiss army motorcycle 1 of 3000 made
1974 A-350 Condor Swiss army " " "
1966 M-274 A2 mule USMC
"Gort, Klatu barada nickto"
Old 10-24-2004, 08:50 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
#1 Green interior on a Trans Am would be pretty rare. You could get any color you wanted but most people opt'ed for black, blue, or white.
#2 With the 12 bolt rear end you could get some pretty high(numerically) rear end gears. The PHS dealer invoice would tell you if the car came from the factory with 3.90 gears.
#3 Norwood, OH cars the Fisher body tag has the basic Firebird 22387 code and WS4 code below for Trans Am. Keep in mind that sometimes the assembly line worker was lazy or goofed up so everything on the cowl tag is not foolproof.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 10-24-2004, 09:02 PM
Dens71TA's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by racerboy:
FWIW - My 1970 Trans Am came out of the Norwood plant with a T/A tag. <HR></BLOCKQUOTE>
So you're saying the cowl tag on your Norwood,OH built '70 Trans Am starts out "ST 70 22887NOR" instead of "ST 70 22387NOR" and doesn't have the WS4 code below?
I know the 70-71 Van Nuys cars have a slightly different cowl tag and T/As had 22887 VIN numbers and no WS4 code but I have never seen a Norwood car like that.
Old 10-25-2004, 06:29 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
- A green interior was one of the available colors for 1970. There was a car like the one
you are looking at for sale around here a while back. It was a white car with a green interior
and reported to be documented as original. I have seen white with brown interior and white with red interior. While non of these were common, it certainly was possible.
-Performance gearing was an option, 3.90 could
certainly been one of those options.
-All of the Norwood cars I have owned showed a
Firebird VIN and then WS4 to denote a Trans Am on the cowl tag.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1996 Trans Am WS6
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
Old 10-27-2004, 04:48 AM
I have seen a couple of white T/As with green interiors.
One was a 71 4-spd car, another was a 72 auto with a/c, and the third was a white column shift auto with no a/c.
I have not seen a 70 T/A with green, but I have seen a white Formula with dark green interior and column shift.
Mike
Old 10-27-2004, 05:21 AM
Never have run across 3.90's in a '70 1/2 T/A. Early magazines tests of a 70 1/2 RAIV T/A showed a 3.90 gear, & the car prob had that oddball 12 bolt ratio as it was a preproduction-engineering prepped car. 3.90's in a 70 1/2 T/A housing, would have to see the dated original GM gears & a buildsheet to believe it...
Colorwise, have ran across one green interior auto '71 T/A, one red interior-column shift auto '70 1/2, bunch of 70 1/2 sandlewood interior T/A's.
Old 10-27-2004, 05:39 AM
racerboy's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> So you're saying the cowl tag on your Norwood,OH built '70 Trans Am starts out "ST 70 22887NOR" instead of "ST 70 22387NOR" and doesn't have the WS4 code below? <HR></BLOCKQUOTE>
Dennis,
I will verify this tonight. Could be that I misread the '223' as '228'. The cowl tag had been painted over and a 'drip' may have me all messed up (amongst other things) I'll let you know.
Frank
Old 10-28-2004, 05:59 PM
70tatim 70tatim is offline
Here are the avaliable axle ratios and codes for the 1970 T/A. The codes are for the safe-T-Track Axle.
cov 3.31
col 3.36
cox 3.55
coz 3.73
The 3.90 was N/A on a production 70 T/A
Old 11-17-2004, 12:05 PM
TA doctor TA doctor is offline
The factory had 6 - 70 T/A's with green interior. 9 with brown interior those two are the rarest. Sandlewood was next, etc.
Old 11-17-2004, 04:09 PM
BlkBird BlkBird is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Jeremy Keller:
70 Trans AM questions
<HR></BLOCKQUOTE>
I only counted 3.
1971 Firebird Espirit
1973 Firebird Formula
Old 11-18-2004, 09:49 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Breed Reno:
The factory had 6 - 70 T/A's with green interior. 9 with brown interior those two are the rarest. Sandlewood was next, etc. <HR></BLOCKQUOTE>
1970 blue on blue TA
1970 white on sandlewood TA
1972 white on blue TA
Old 11-19-2004, 07:33 PM
Hey Breed, where did you get the info on the numbers of specific colored interiors? You said Sandlewood is the next rarest after green and brown, any idea how many sandlewood interiors? Mine is a 70 T/A, lucern blue with the deluxe sandlewood. Also, any idea how many of the 4 speed cars came with factory a/c?
Old 11-21-2004, 02:47 PM
wish I could tell you where the info came from but not able. Trust me it's correct. I'll contact my friend Mon. and check on the blue / sandlewood for you.<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by eaglesan13:
Hey Breed, where did you get the info on the numbers of specific colored interiors? You said Sandlewood is the next rarest after green and brown, any idea how many sandlewood interiors? Mine is a 70 T/A, lucern blue with the deluxe sandlewood. Also, any idea how many of the 4 speed cars came with factory a/c? <HR></BLOCKQUOTE>
Old 11-22-2004, 09:59 AM
[I'm told 11 cars had blue / sandlewood ,right now 3 good vin's out there on that color.
Old 11-22-2004, 01:16 PM
R 70 Judge's Avatar
R 70 Judge R 70 Judge is online now
Breed Reno, Do you have any info on '70 Judges? Atoll Blue, Blue int, 4 speed?
Hey, it's worth a shot.
James
1970 Trans Am
