Old 09-13-2003, 08:07 PM
ron thorne ron thorne is offline
anybody know of an application that has the same installed height as the original? i have the shaker scoop and hood but no base. tried one off a 75 455 grand safari(donor motor) but was about an inch too tall.
Old 09-15-2003, 07:07 PM
have you tried one from a trans am?
where's winslow at?
mike
former." --Albert Einstein
- Winston Churchill
Old 09-15-2003, 07:33 PM
Held for Ransom's Avatar
I would think the 1973-76 Trans Am bases are the same as the '74 GTO.
So long, farewell.
Old 09-15-2003, 09:09 PM
Gooatee's Avatar
Gooatee Gooatee is offline
I believe the only one that is a direct swap is the 77 Can Am as it used the 74 GTO scoop!
Old 09-16-2003, 04:49 PM
johnta1 johnta1 is online now
I think the bases would be the same as the 73- on TA's as Held said.
The height differences was made up on the scoop assembly.The GTO had a taller spacer added to the scoop mounting flange.
johnta1
Old 09-16-2003, 06:28 PM
Mike: no, i havent. (southern, in). held,goatee, &john: thanks. just thought there might be something commonly available(i.e. non ram air) at a salvage yard since the base off the land barge (grand safari wagon) wasnt that far off. i will keep scrounging. thanks for replies. Ron
Old 10-04-2003, 08:30 PM
wildman131 wildman131 is offline
I know of a place where you can get the whole assy for around $200. eastwestautoparts.com - they are a salvage operation in Tulsa,OK - called them couple years ago and was quoted $175 plus s&h.
