Old 08-03-2003, 09:36 AM
Poochie's Avatar
Poochie Poochie is offline
I'm sure this has been covered before, but I can't seem to find anything in the archives about it. Will the HEI distributor from the 301 fit in a 350? Seems I can only find 301's in the wreckers around here.
Cheers,
Poochie
"The will to be stupid is a powerful force."
Poochie's Avatar
Cheers,
Poochie
Old 08-03-2003, 10:18 AM
He He is offline
The 301 has a way shorter deck height. Hence a much shorter distributor.
He, who laughs last...
Old 08-03-2003, 10:31 AM
Distributor length is the same, though deckheight (where the head mounts) is different... back area by the distributor is same dimension. That said, any HEI distributor should be recurved for best performance.
Old 08-03-2003, 10:56 AM
Steve Barcak's Avatar
HE....
Nonsense. ALL Pontiac V-8 distributors interchange from 1955-1981 with no exceptions, except for the 455SD and Ram Air V. Some people , for some reason, think that some Pontiacs rotate the opposite direction, that is not true either.
There are differences in the distributors over the years yes, but they will interchange. Remember the later 301s and 265s do not have vacumn advance. and yes, recurve them to your application too.
Steve www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 08-03-2003, 12:57 PM
He He is offline
My bad.
He... is feeling kinda stupid now. But it's sunny.
Old 08-03-2003, 04:32 PM
ifixit4me ifixit4me is offline
So... this will mount in my mid 70's 400 with no probs right?
http://cgi.ebay.com/ebaymotors/ws/eB...category=33690
Tracy
If you want to kick the tiger in his ass, you'd better have a plan for dealing with his teeth.
Old 08-03-2003, 07:56 PM
Yep. But do the recurve.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 08-04-2003, 08:31 AM
Poochie's Avatar
Thanks all!
Poochie
Old 08-05-2003, 06:30 AM
Kybird Kybird is offline
I got the HEI in my 400 from a "U-Pull" lot out of a 78 301. They only have about 7-8 degrees of mechanical advance and 20+ degrees of vacuum advance. If you are going to change mechanical, definitely need to limit vacuum adv!
Old 08-05-2003, 08:49 AM
cjwilson99 cjwilson99 is offline
Am I the only one that noticed that distributor was for Chevy Blocks only. The only pontiac that dist will work for is one with a Chevy engine.
Old 08-05-2003, 09:19 AM
CJ. Believe your comment is towards the e-Bay auction, agree the pic is for a new import Chevy HEI distributor. The seller may have a deal & is providing whichever marque of non electronic HEI, at the close of the auction, but like you, not sure. Hard to believe that anyone would tool up for Buick, or Olds, or Pontiac HEI bodies.
Old 08-05-2003, 10:09 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Aubrey Parker in Dallas once told me the 301s have a pretty decent curve and the junk yards sell they cheaper as thery are 301s!
Skip Fix
