Old 10-21-2003, 09:15 AM
TATA79 TATA79 is offline
No interiorlights come on when my door opens, no blown fuses all new bulbs, any ideas.
Old 10-21-2003, 11:07 AM
chucks79ta chucks79ta is offline
Could it be a door switch?(very common) Have you checked both doors? How about the headlight switch itself will they work with that?
If I have too live life on my knees I'd rather die on my feet.
1979 Trans Am 1975 Formula
Old 10-21-2003, 12:12 PM
dyingbreed's Avatar
dyingbreed dyingbreed is offline
I agree with 79ta's post. Try checking both door switches. They should be mounted near and below the front door hinges. The switches look like little pins and should move in/out freely. Make sure these switches are not stuck. Wiggle them around a little bit and spray some type of lubricant on them .... WD-40 should work. Let us know how you made out.
db
Making a living is not the same thing as making a life!!
Old 10-23-2003, 08:55 AM
No luck
Old 10-25-2003, 10:36 PM
78 GHOST 78 GHOST is offline
You did not elaborate on the function of the dome light with the headlight switch.. very important to know this. If your dome light works with turning the headlight switch, you have eliminated the light itself. Look at the switch, then wires, then fuseblock.
Remove the door switch, check for 12V at one of the wires on the switch. If you have 12V, at one of the wires, your switch is bad.
If you do not have 12V at the back of the switch, the problem is "upstream" between the switch and the fuseblock. Check for continuity between the switch and the appropriate pin on the fuseblock.
Many times, on vehicles 25 years old you will find corrosion at the fuseblock.
I hope this helps some, -Matt
____________________________________
Much love out to my Peeps
"I work in high speed aluminum tubing."
Old 10-26-2003, 05:21 AM
dragula81's Avatar
dragula81 dragula81 is offline
I don't think you'll get 12 volts at any of the door switches. Most door switches complete a GROUND circuit when the door is opened so the switch will never have voltage to it, only grounding.
I've never checked them on a 70's T/A but that's the way that I have seen most door switches.
Drag
"How to become immortal: Read this signature tomorrow and follow its advice"
http://webpages.charter.net/dragula7
Drag
www.dixiemusclecars.com
The Southeast's only online Community dedicated to the American Muscle Car!
2006 PBM GTO LS2
1995 Arctic White Trans Am LT1
1981 Trans Am Daytona Pace Car
1969 Gold Poly Firebird w/400
Old 10-26-2003, 07:11 AM
Drag, that makes more sense. In that case, you can just do a continuity chech of the switch in each position.
