Old 02-15-2005, 07:07 PM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Waiting for my new 455 shortblock. Looks so empty. The 350 is gone....
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Jagtec1's Avatar
Darin
9.81 @ 136.39MPH
Old 02-15-2005, 07:19 PM
gobrdgo gobrdgo is offline
Looks familiar, I'm waiting on my block, crank rods, and my heads. IT'S KILLING ME!!! I'm trying to use the down time to detail my engine compartment/frame and stuff but motivation is down without a powerplant. Did you convert from power brakes? I would like to do that to my T/A.
Old 02-15-2005, 07:32 PM
screamingchief's Avatar
screamingchief screamingchief is offline
Thanks for posting the pic,I was wondering which side the taller engine frame mount went on.I have to install the frame mounts in my 70 race car and was not sure,they had a BBC in it before and I did'nt remember which side they came off of the donor car(its frame was cut up like a jigsaw puzzle.I got you beat too,I have two lonely engine bays,but only for a short time.First the lemans/GTO racecar.
This space for rent...
In the meantime,check out the cars HERE.
Old 02-15-2005, 07:33 PM
And my 72 firebirds.
Old 02-15-2005, 07:36 PM
Jagtec1's Avatar
Yes, I did convert to manual brakes from power. Wilwood Mopar style aluminum MC.
Darin
9.81 @ 136.39MPH
Old 02-15-2005, 09:21 PM
On the brakes, Is that it? Just bolt on the new master? How much? Thanks alot!
Old 02-16-2005, 04:23 AM
Jagtec1's Avatar
I had to modify the mounting flange on the MC, as the Mopar style bolt pattern is slightly more narrow. I just drilled and filed the holes carefully to fit. I had to bend lines for the proportioning valve. I still need to fab a mounting bracket for the valve, but yeah, that's about it. The Wilwood unit was nice because it cam with the pushrod, so I didn't have to make one. I reused the clevis, and moved the pushrod to the upper hole on the pedal arm. I have not been to the track yet, but I'll report. Cost was about $115.00 or so for the MC.
Darin
9.81 @ 136.39MPH
Old 02-16-2005, 06:04 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
ScreamingChief. The taller mount is on the drivers side on my 66 GTO. Now I am wondering if mine is backwards . -Jim
Old 02-16-2005, 10:56 AM
JOE DEYTON's Avatar
JOE DEYTON JOE DEYTON is offline
The drivers side is the tall one, on all 64-72 Pontiac A bodies.
Old 02-16-2005, 11:33 AM
Brian '74's Avatar
Darin,
Do you have a part # for the MC? My car has manual brakes, but I am going from drum/drum to 4 wheel disk.
Old 02-16-2005, 11:48 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Well here's a new motor almost ready for a new "home".
Skip Fix
Old 02-16-2005, 03:25 PM
Big Chief 541's Avatar
Big Chief 541 Big Chief 541 is offline
Skip, it looked better with the crossram
Well, I mean it look's GREAT, but that crossram is just killer looking
MY SHOP-MY GATOR MY RULES
Old 02-16-2005, 04:07 PM
Skip Fix's Avatar
I don't think I can get the Shaker to fit the crossram!
Just about everythings buttoned up to go dyno this thing.
Skip Fix
Old 02-16-2005, 07:29 PM
fast72lemans's Avatar
fast72lemans fast72lemans is offline
Send a message via MSN to fast72lemans
Don't feel bad Darin, It must be a northeast thing!!!!
Old 02-16-2005, 07:43 PM
Jagtec1's Avatar
Brian, the Wilwood # for the kit is 260-4894, and the # for just the MC is 260-4893.
I'm just waiting on the shipping amount from the Dude for my shortblock, then I can proceed! Got the whole fuel system to plumb, the motor has to go together, get mocked up with trans to measure for driveshaft....etc...
I've bitten off almost more than I can chew.
Darin
9.81 @ 136.39MPH
Old 02-16-2005, 07:45 PM
Flamin65's Avatar
Flamin65 Flamin65 is offline
I don't feel so bad now. My heads are in the machine shop as we speak. When I ge those back it's 462 Blower motor, Hopefully, if nothing else goes wrong.
Old 02-16-2005, 07:48 PM
Flamin65's Avatar
Here is the closest to finished I can do.
Old 02-16-2005, 07:49 PM
Flamin65's Avatar
And another.
Old 02-16-2005, 07:50 PM
1964GTOJEFF 1964GTOJEFF is offline
what kind of headers are on the lemans 72?
