Old 04-18-2005, 06:57 AM
peppergreen's Avatar
peppergreen peppergreen is offline
Folks,
Replacing the engine compartment harnesses in my 70.....what's the best way to clean the receptacle? Q-tips, contact cleaner spray?
As well, is there a type of grease or spray that needs to be applied before they are connected?
Thanks a bunch
Brent
"Drive a GTO".......Iggy Pop-Lust for Life
Folks,
Thanks a bunch
Brent
Old 04-18-2005, 11:00 AM
6t7gto's Avatar
6t7gto 6t7gto is offline
pepper,
i just changed mine out and didn't use anything. no problems.
just make sure all the prongs are the same length. when i got my 67 it had an auxiliary starter button under the dash. Previous owner said it was like that when he got it.
evidently, someone pulled on the engine side of the harness and pulled the prong out from the terminal. just enough that it didn't make contact.
unless your contacts look corroded, i don't think you need anything on them.
david
Old 04-19-2005, 11:49 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Also make certain the wiring is correct. I replaced the harness in my 70 GTO and a couple of the wires were swopped going to the voltage regulator and my battery kept dying. It took a while to figure out.
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 04-20-2005, 08:31 AM
Good info guys, thanks.
