Old 04-18-2003, 02:14 PM
theYman's Avatar
theYman theYman is offline
I have e-heads on my 455 and am attempting to check valve lash but have no clue as to the cam.so what lash # should I use?Right now I'm getting between .010 to .013cold,so according to crane's website I should add .006,because of alluminum heads. which means I'm getting .016-.019.correct?
Maybe Someday.....
http://www.theyman.com
The thick CLOUD of tire smoke ,the SMELL of burning rubber,and the CHEER of the crowd ....PRICELESS.
$90.00 fine for an awesome burn-out,worth every penny...
http://www.youtube.com/watch?v=iI7beXh7xW8
theYman's Avatar
Maybe Someday.....
Old 04-18-2003, 02:35 PM
Goatman Goatman is offline
On Vacation
I would go .020-.022 if I were you and then work it down from there.
Chance favors the prepared mind.
Old 04-18-2003, 03:49 PM
basketcase70gto basketcase70gto is offline
I JUST BOUGHT SOME AFR HEADS FOR MY BIG BLOCK CHEVY AND THEY SAID THE HEAD GROWS ALOT MORE THAN THE REST OF THE VALVETRAIN SO YOU SHOULD SET THE LASH .006 TIGHTER WHEN COLD WHICH A .013 OR .014 WOULD PUT YOU AT .020 WHEN HOT. A GUY I KNOW PUT E-HEADS ON A FORD 428 AND SET THE LASH THE WRONG WAY (.006 LOOSER NOT TIGHTER) AND BENT A FEW PUSH RODS THE FIRST TIME HE REVED IT UP. lIKE GOATMAN SAID .020 TO .022 HOT IS WHERE YOU SHOULD END UP.
Old 04-18-2003, 04:02 PM
theYman's Avatar
so .014 is where i should be cold?i think i got it.
Maybe Someday.....
Old 04-18-2003, 06:46 PM
On Vacation
Should give you a good starting point. Just go easy on the motor untill you get it all figured out.
Old 04-18-2003, 07:10 PM
tempest455's Avatar
tempest455 tempest455 is offline
When I ran a solid w/ my E heads I set the lash at .019-.020. Ultradyne recommended .026 Hot and it was usually pretty close.
Tempest455
http://www.wauknet.com/douthitt/
Tempest455
Old 04-18-2003, 07:32 PM
theYman's Avatar
I wonder why all the valves are much tighter than this now?I'm getting lash readings of .005 on many of the valves?How would this affect the valvetrain?wouldnt it increase the cam overlap slightly?
Maybe Someday.....
Old 04-19-2003, 07:00 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
Most solids have lash settings in the .020 to .030 range. Mine is .024 to .026. Since i run Eheads alos i set them at .019 & .021. You better find out what you have before you don't have it anymore.
Old 04-20-2003, 05:20 AM
theYman's Avatar
I adjusted them to.013 cold and man is it noisey! I'm not sure if I like solids anymore.I then went back to what they were before .05 cold and the rockers are quiet and the motor revs faster???Im confused...
I wanted to clarify my intial post of this subject.The first time I checked the lash cold I got .013 on 2 valves and the rest were tighter.They were.05 to .09
Maybe Someday.....
[This message was edited by theyman on April 20, 2003 at 08:33 AM.]
Old 04-20-2003, 05:20 PM
theYman's Avatar
I THINK I have hydralic lifters after all....dont I? look at picture..would explain all the trouble I've had...boy I feel soooooo stupid
Maybe Someday.....
[This message was edited by theyman on April 20, 2003 at 08:37 PM.]
Old 04-20-2003, 06:46 PM
Thats a Hydraulic lifter. Go to zero lash then 1/4 turn more & lock her down.
Old 04-20-2003, 07:14 PM
theYman's Avatar
Thanks Scott,I hope I didnt damage anything.
by-the-way I LOVE the new Summit racing showroom.I cant wait to go back and drool,I wonder if they mind if I pitched a tent in there?
Maybe Someday.....
Old 04-21-2003, 05:14 AM
Thanks for the compliment. Just check all the lobes to see if they have started to round. If all the lobes look good & the bottoms of the lifters do also put it back together.
Old 04-22-2003, 08:49 AM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Trent, don't feel stupid, we all have to start someplace, that's what this board is for. Anyway for an excellent procedure on valve adjustment click onto Pontiac Dudes web-site an go down the page and click onto Valve Adjustment Procedure. http://www.pontiacdude.cc
Robert Williams
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 04-22-2003, 03:17 PM
theYman's Avatar
You know I have been workin on pontiacs for almost 20 yrs now.......so truth be told... I AM STUPID! I have never seen a hydralic lifter that looked like this one...oh wellllll..anyhow the motor is back together and the HYDRALIC lifters are adjusted and all are quiet.This 455 really runs now!14 inches of vacum at idle and a lopey idle... did a small power brake in reverse...HOLY CRAP....almost took out the garage door.roadtest coming soon.
Maybe Someday.....
Old 04-23-2003, 06:35 AM
Glad to here all is well. We all learn somehow just like Robert said.
Old 04-23-2003, 07:20 AM
theYman's Avatar
Road-tested last night,I'm gonna need new rear tires very soon.
It CAN happen!
