Old 01-07-2003, 04:34 PM
khogan khogan is offline
I need to replace the old valley pan on my '66 GTO 389. The old one has a hole for the pcv. Also, the driver side valve cover has a filler cap and the passenger side valve cover is solid. Where can I get a replacement for this, and is this engine vented properly?
Old 01-07-2003, 04:38 PM
Goatman Goatman is offline
On Vacation
Indian Adventures.
1-888-RAM AIRS
Chance favors the prepared mind.
Old 01-09-2003, 02:37 PM
Is this vented enough?
Old 01-09-2003, 02:52 PM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
I have a spare stock valley pan I don't need anymore. Make an offer and it's yours.
Honest dad, that 455 on the side of the block is a serial number
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 01-09-2003, 09:49 PM
455Dave's Avatar
455Dave 455Dave is offline
If I remember my old class in pollution controls correctly, there should be two air paths. During driving conditions when there is manifold vacuum, the PCV valve will pull air from the engine preventing acidic conditions from occuring in the oil. A seperate breather provides an air path through the engine, sort of like scavenging air.
Under WOT conditions, the PCV valve seats, blocking the air passage and the breather tube provides a path to vent any pressure buildup in the crankcase.
Are the valve covers the factory originals?
Old 01-10-2003, 12:59 PM
To the best of my knowledge, they are the correct valve covers for a '66 GTO - 389.
Old 01-11-2003, 07:03 PM
455Dave's Avatar
Sorry, but I don't know much about goats, you might want to post a question over in the appropriate year GTO forum.
You setup sounds almost like the old breather tube cars, solid valve covers with a breather tube near the back of the block to vent gases from the crankcase but I can't ever remember seeing one with a PCV valve.
If you are looking for an aluminum valley pan with a PCV provision, Pontiac Dude sells them, I have one for my T/A.
