i have had alot of trouble with my 1966 pontiac starchief executive. when ever it rains or is damp, it seems like all the juice from my battery is drained and the car wont turn over. i have checked all of the grounds, i have replaced both battery cables, i have checked alternator, battery is new. every thing has checked out ok. any ideas to solve my problems would help.
every day is a good day to work on a pontiac
every day is a good day to work on a pontiac |
Make sure the connection to the starter is clean and tight.
Also that the block to starter is clean and tight. There is a connection or union in the wiring harness just behind the alternator wiring,make sure it's ok and not corroded or broke.There's a fusible link in there too.Check it. johnta1 Pontiac Power RULES !!! www.wallaceracing.com
John Wallace - johnta1 Pontiac Power RULES !!! www.wallaceracing.com Winner of Top Class at Pontiac Nationals, 2004 Cordova Winner of Quick 16 At Ames 2004 Pontiac Tripower Nats KRE's MR-1 - 1st 5 second Pontiac block ever! W.E.C moment "Every man has a right to his own opinion, but no man has a right to be wrong in his facts." "People demand freedom of speech to make up for the freedom of thought which they avoid." – Socrates |
Just because the battery is new dos'nt mean its o.k.
I run into this all the time. (I mean with new parts). There is a leak. However at 12 volts theres not much potential for arching in damp conditions. I would start with the battery. Did it do this with the old battery? Is there any one part you replaced before this started happening? Good Luck |
GROUNDS GROUNDS GROUNDS GROUDS
only when wet? cracked cap?
can you hear me now? is this thing on? test 1 2 1 2
can you hear me now? is this thing on? test 1 2 1 2 |
Funny thing, I just had the same exact problem with my 98 Ram. Only when it was wet or damp outside it would not start. Battery cranked fine, etc, etc. I finally did a tune up on it and the the plugs were way out of gap and also the distributor rotor/contacts were corroded. Been running like a champ since then. So that is the place I would start.
1969 GTO convertible, starting it soon..............
Where have all the good ones gone? |
In his question he said it has 'NO' power. I took that as meaning no cranking,lights etc.
Cap,ignition wires won't affect this. But,if he does have cranking power,then I would look into those things. johnta1 Pontiac Power RULES !!! www.wallaceracing.com
their is still power, the headlights still work but their isnt enough power to crank the engine. i have checked every thing over and over. it is an unsolved mystery
Try a good starter or solenoid.
Also did you check the joint where the wires connect in the wiring loom? johnta1 Pontiac Power RULES !!! www.wallaceracing.com
that is the only place where i havent looked
