Old 04-15-2005, 02:07 PM
Rob Rob is offline
IAII Allpontiac.com aftermarket Pontiac Block Cometic Head Gaskets are in!! $172.00 a pair visit http://www.ictcengines.com/cometic.htm for sizing and options.
Rob Rob is offline
Old 04-15-2005, 06:44 PM
J.C.you's Avatar
J.C.you J.C.you is offline
rob, when should i get mine? were they dropshipped?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 04-15-2005, 07:22 PM
SupergasDil's Avatar
How much compression or boost will these bad boys take? Without o ringing?
I'm at 12.25 to 1 6% underdriven with 8lbs boost. I'd like to go 1 to 1 on my drive and that would set me at 13.5 to 1.
Old 04-15-2005, 07:55 PM
Rob Rob is offline
JC, your's should've been dropshipped, actually you should've got yours today. I will double check on Monday.
Supergas, these don't get o-rings. The 4.300 small bore design gasket with valve relief fire ring has held on engine with 18psi boost. The larger bore design has the stronger "round" fire ring and center layer embossing won't know how much past 11-1200hp it will handle till someone does it.
The latest consensus is that the cometics will take everything any copper and o-ring will. The flip side is that when engine lean outs or other acts of god that burn a copper gasket clean out and damage the head at most, will torch cut the head and block because the Stainless steel in the Cometic gasket refuses to burn away.
-Rob
Old 04-16-2005, 06:02 PM
Flamin65's Avatar
Flamin65 Flamin65 is offline
Rob did you get my gaskets out yet? I thought I was going to have them by Friday but I guess not. They were the 4.200 x .036 I ordered them last Friday. This is Greg in Virginia.
Thanks Greg
Old 04-16-2005, 06:23 PM
Rob Rob is offline
I will check on that Monday also, Cometic is behind, but your's should've made it out this week too.
-Rob
