Old 01-09-2003, 07:27 AM
pontiarrg pontiarrg is offline
I am about to remove a 1978 305 chevy (170hptruck motor yech !) w/300 trans from my 67 bird and install a 400pontiac 425hp w/th400 transmission. I am wondering if there are going to be any nasty suprises on the engine mounts or transmission crossmember. the rear appears to be a stock 10 bolt posi and i have a short shaft 400 xmission. please advise
No GTO doesn't mean garbage truck option!
Old 01-09-2003, 10:04 AM
drewhelm1974 drewhelm1974 is offline
I just did this switch. You will need Pontiac motor mounts and mount brackets(any 67-69 F-bird motor mount brackets will work), a TH400 crossmember (found on e-bay for about $50), TH400 driveshaft slip yoke, and have the driveshaft shortened about 1/2-3/4 if an inch.
69 Firebird, FINALLY installed the Pontiac 469.
01 Red and pewter GMC Ext Cab SIERRA SLT 4x4
02 Maple Red (maroon) LS1 Trans Am
69 Firebird, .060 over 455, UD solid roller 254/262 @ .050, Scorpion rockers, home ported 6X-4 heads, Holley 850 DP (bone stock), Holley SD intake, with Summit 3 inch x-pipe and goerlich Xlerator mufflers. 12.27 @ 115mph.
02 Midnight Blue LS1 Ram Air Trans Am WS6 (440 rwhp)
http://firstgenfirebird.org/show/closeup.mv?CarID=642
